guys with trunk tank please help
Ive had my trunk tank for a little over a year. I got this tank with a rule 2000 pump built inside the tank is from chawkins2001 and this is the first problem Ive had. Its wired to come on as soon has I press the push start button but today I notice it was not running. the only thing I have done is add some water wetter in the tank thats it. any help would be great thanks.
Thanks again, after I had time to take a good look it was just a wire that was the problem. I have now noticed that the fluid level in the tank is dropping a little bit. Any insight on why this may be ? Running a mix of distilled water, mb coolant, and 2 bottles of water wetter.
My Rule 2000 failed after less than 3 months and I'm getting it replaced this week. Unfortunately the vendor I bought the pump and tank from is totally unresponsive after over 2 months of trying to grt him to send me a new one, so I'm replacing it out of pocket. Lame.
Do you know how it failed?
Sry to hear. Mine was just some lose wiring but as started above the fluid level in the tank seems to be going down a bit, maybe the distilled water that's in there is evaporating some ?
another question guys. my 30 amp green fuse was fried so I had some weaker 10 amp fuses laying around to test and make sure my pump wasnt bad, so I popped it in and heard the pump try to start up the the fuse blow which I knew it would being it was not a 30 amp fuse. This is where Im stuck, I get some new 30 amp ATC fuses put it in the fuse holder and nothing. could I need a new fuse holder as well ?
If you want to learn how to use an volt meter to diagnose your problems, just ask or just search on youtube....
Sorry if you feel I am being a dick ...
No worries on the comment either...
My rule 2000 failed after about 1 1/2 year.
PLATINUM SPONSOR
A blown fuse can also be the sign the pump is starting to fail, as it starts to draw more amps when going bad. The rule pumps are good but if they are getting to much back pressure, they can fail early.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Another reason to run a dual set up with a Meziere up front and a Rule out back. If the Rule fails the Meziere is strong enough to run the whole system and vice versa.
I am running 2 pumps. Front pump is running still but I can tell it's getting weak because car feels slower with just that pump working plus it's not the 010 Bosch model
This is the correct pump I'm assuming Could u please verify Craig or anyone else that is running a rule2000 pump in the tank thanks
This is the correct pump I'm assuming Amazon.com: Rule 10 Marine Rule 2000 Marine Bilge Pump (2000-GPH, 12-Volt): Sports & Outdoors
Would the "upgraded" Bosch 010 work just as good ? I ask because I know u have to make some modification to hold the meziere pump. I was told the rule pump was power enough to push thur the front pump.
