Hiccup /p0102 and AFR
I still have that occassion hiccup / P0102 MAP code that is driving me crazy.
I just installed my AFR gauge. At idle in drive, my afr shows a steady 13.8-14.0. But, with the hiccup or P0102 MAP code, my afr at idle in drive jumps to 19.2 and moves between 19.2 and 20.9.
SOMEONE has to have solutoin to this hiccup / P0102 MAP problem? Anyone?
At WOT, AFR is at 10.9-11.2. With the hiccup, the AFR at WOT is 12.4-12.5.
I again checked all the connections, lines and so forth. There is no air or vacuum leak. I can not figure the cause of this MAP code / hiccup.
The only fix at this time is to turn off the car and restart do not try to drive around after the hiccup as in those lean conditions it may do damage or pop it altogether. It is not a vac leak or anything like that it just seems that the ecu chooses a different map and all goes haywire
Have you changed your MAP sensor? Not sure what the history is for your car - what have you tried to change? What is your AFR at partial throttle and at WOT? If there is a big jump in AFR from 14.7 to say 9, it would also possibly cause hiccup.
My AFRs do dip from 14.7 into the 9s at part throttle. Why do you suspect this may be relevant?
I'm still experiencing hiccup mode from time to time. It's frustrating and, if one's not very careful, can result in catastrophic failure. A new MAP sensor made no difference on mine and (as far as I can gather) nor did it help any of the others who've replaced the sensor.
Still the same tuner here - Weistec - Nothing has been done on my car as yet to try and resolve the issue via the tune. I will be sending them logs soon with a view to updating the break-in tune they sent me - hopefully the changes that are made will resolve the issue
If it is a sharp transition especially at part throttle, then that is your issue. Cars do not like sharp transitions. You probably go from a nice 14.7-15 (closed loop) to 9 all of sudden and back again … as the car jerks, your foot will jerk also exacerbating the issue. Time to talk to your tuner about the issue. Jump in engine timing as it switches between can also be an issue. Your AFRs should not go that low. AFR in the 11s is safe enough.
Has anyone actually linked this to the TB? To me that just never made sense and seemed to be more coincidence than anything else. I think it's more of a tuning virus. Tuners have copied each other's tunes for so long that we have a bad tune getting passed around under different brands. I'd like to see a tuner start from scratch and build a tune based off a perfectly running stock tune instead of loading their base and tweaking for mods.
