Visit Workshop Suspension Error (I know...)
BMW M5 + E55 AMG
Done lots of searching, I know it's common on our beasts.
I've been getting it sporadically lately but this week it happens immediately on start up. A few days ago I tried the raise button and nothing happened. Tonight, I noticed my rear wheels are sitting reaaaally low, passenger's side more than driver's. Fronts are also a bit lower than normal but not slammed.
Before I go throwing money at rear air springs, is there a way to test the compressor? The gradual lowering over the past week + no response from Raise makes me think something is up with the compressor and/or relay.
Thoughts?
Thoughts?
With the car running press the button to pump up suspension, You will here pump running on left front behind bumper, if the suspension goes up then the pump is ok, u probably have a air leak somewhere in the system after the valve block.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Most times a leak in the lines, junctions and or struts, causes the compressor to work overtime. When the pump works over time it dose not take long for it to burn up, but that is not all, it almost always takes out the relay too.
So at the end of the day, neglecting that little red visit workshop, just starts costing more and more.
On these cars it is best to be a little proactive with AirMatic issues.
BMW M5 + E55 AMG
It was not a red error code. It was the normal white one. It would go away after a restart, up until this week at which point I had barely driven it.
BMW M5 + E55 AMG
Looks pretty sick, though.
BMW M5 + E55 AMG
Now for the relay, what do you mean check it? Isn't it just a little green box? What signs should I be looking for that would point to it as the culprit?
Thanks for all the help so far guys
2003 SL55, 1978 280SL, 2007 ML63
http://www.ebay.com/itm/AUDI-ALLROAD-C5-A8-Q7-WABCO-AIR-SUSPENSION-COMPRESSOR-PISTON-RING-REPAIR-FIX-KIT-/151062196437?pt=LH_DefaultDomain_0&hash=item232c0230d5
I used to get the visit workshop message occasionally and this kit fixed my problem. Its a shot in the dark but for $30 it might be an easy fix. (The bolts and o-ring are the wrong size but the piston seal is what you need)
BMW M5 + E55 AMG
Mercedes-Benz E500
Audi Allroad C5 A8 Q7 Wabco Air Suspension Compressor Piston Ring Repair Fix Kit | eBay
BMW M5 + E55 AMG
Turned out to be a blown compressor. Would barely register any PSI on the DAS test. Apparently there was a code for a leak, too. Based on the slammed rear, my guess is it's back there. Yay! -_- Edit: tech said the nozzle at the main air line to the compressor was cracked. That's what was causing a slow leak over time, and eventually crapped the compressor. Spray tested all the lines. No leaks! The car rides even better than when I bought it last Fall, much more stable and responsive. Feels more sportier than the bloaty/cumbersome way it was. I thought that all E55s were super soft, pleasantly surprised to see they're not!
Did you take it to an Indy or MB dealer ?
I assume the car cannot be driven with the suspension slammed like that hence you had to get it towed eh or the car rises once you start it and
stays rises as long as it's being driven ?
BMW M5 + E55 AMG
I had it towed because it was unsafe to drive it that low. It is not possible for the car to rise because the compressor was blown... there's nothing to pump air into the system. Took it to a reputable MB specialist shop that has been servicing this car since '07. It wasn't cheap, but that's to be expected.
BMW M5 + E55 AMG
I'm in Canada. Arnott pumps are around $450 in the US actually. All their prices have shot up, even for struts. By the time I factor in shipping and duties, a new local OE unit for $470, in stock at the shop, was a no brainer. The extra costs came in labor/diagnosis (obviously) and some other little things they had to tidy up. I can't complain.
