PLM H/E Installation..... anyone have pics?
I've been pouring over the MBWorld archives and haven't really found what I'm looking for (yet)
My car is a 2006 E55 and has the extra oil cooler, so I am looking for an upgraded H/E solution that accommodates it without requiring the use of "zip tie technology"..... call me OCD, but solutions like that aren't going to work for me. Research indicates:
I have seen that the EC version requires cutting of the bumper mount on the side where the coolant lines are... I'm not sure if the PLM has a similar requirement? :nix: Also, I'm not sure if the PLM will push the chin spoiler down at all once the oil cooler is re-installed? So....... I'm hoping that those of you who are actually running the PLM setup on an '05 or '06 E55 (with the oil cooler) took a few photos of the installation and can help me to identify how the H/E actually bolts to the front bumper area, and can reassure me that PLM doesn't create the "fat lip" issues like the larger FTP-type solutions....??? Thanks! -G |
Greg, if you want to come down to Cambridge, I have a PLM I need to install
Originally Posted by 55fanatic
(Post 5962817)
What year is your E55? I'd love to check out the install or at least see some pics once you get it done. I assume your are doing a split-cooling mod at the same time (BMW or Cobra reservoir)?? -G |
Mine is an 04
I got the EC one and my car has the oil cooler. It is an easy fix by just zip tying the cooler.
The bulge will be there on a stock bumper once everything is re-installed. I did not take any pictures of the installation (it is quite simple), but I can take a few to satisfy any fitment concerns post installation.
Originally Posted by O-55
(Post 5962875)
Does the oil cooler get the same kind of airflow that it did stock, or does the new location cause it to get blocked by the bumper lip? A few photos would certainly clear things up if you can snap a few.... :y -G |
The unit is secured using existing hardware from the front support beam. It sits flush underneath the beam once everything it tightened up. You will also re-use the grommets from the oil cooler mounts.
I'll take pictures of the finished product with and without the front undertray installed to help clear up your airflow concern. |
I have the PLM also although not connected with my current setup and it is the most stock like install of any of the larger HE. Bolts right to the factory spots and the oil cooler bolts right on too.
I have an 05 with E63 front now but don't recall being much of an issue with any bulge before with the OE E55 bumper. To me its the best bang for the buck and best install. |
I have the PLM on the way and will try to take pics and all when I install. I went with the PLM unit because of this same reason.
I also have the PLM on my 06. Super easy bolt on installation and the bulge isn't bad at all . Not even noticeable with a lower lip installed.
Since my wife was "NICE" enough to "REMOVE" my carbon lip for me I will take a picture of the stock bumper with the PLM installed. |
Originally Posted by ss.dna02
(Post 5963106)
Best I could do was around $350 shipped... :nix: -G |
I went directly to PLM.
I honestly didnt look around. I regret not doing that now. $350 shipped would have been nice !! |
I put it in my sticky...last post in DIY https://mbworld.org/forums/w211-amg/...-addition.html
I'll just pot a link to both for you. https://mbworld.org/forums/w211-amg/...r-upgrade.html |
1 Attachment(s)
i just finish the heat exchanger install 2 days ago. the only issue i have with them is the hole they drilled on the bracket is about half inch off i had to redrill to be able to mount them on my car. but other than that its pretty easy swap.
Originally Posted by MAN55LE
(Post 5963308)
Originally Posted by Jeffchai
(Post 5963413)
MOAR PICS!!!! :rolf: -G |
I just got my PLM in the mail today so I will be installing it on my next day off. I'll take pics.
2 Attachment(s)
Originally Posted by GregMB
(Post 5963557)
Thanks for the links! The bumper removal stuff is helpful. The rest of it looks substantially different from what I was planning to do... (different H/E and extra cooler) but it all provides good context for the swap.
Nice pic! Thanks... So is the typical interference point in those lower corners of the H/E? From your photo that seems like the most likely spot.... or maybe it's the entire underside of the oil cooler once it's bolted back in?? :nix: MOAR PICS!!!! :rolf: -G here's 2 more pictures. every thing fits fine i just had to redrill the tab at the end to mount it on my car other than that its a bolt on deal. |
The PLM is GTG, mine has been on for years with no issues or concerns as it is bolted on. Bulge will be present- unless you go with the E63 bumper. HINT HINT
PP,
What specifically causes the "bulge"? Is it the oil cooler pushing down on the chin spoiler across the bottom, or is it the lower corners of the H/E that end up hitting? :nix: -G |
Originally Posted by pearlpower
(Post 5966912)
(Post 5966973)
PP,
What specifically causes the "bulge"? Is it the oil cooler pushing down on the chin spoiler across the bottom, or is it the lower corners of the H/E that end up hitting? :nix: Combination of the a taller/lower H/E pushing down the under tray/bumper. Never bugged me. -G
Originally Posted by chawkins2001
(Post 5966983)
Where have you been brotha, good to see you posting again :zoom:
How much coolant would I need after I replace the H/E ?
And are any of you running water wetter or Royal purple Ice ? |
(Post 5969849)
(Post 5966973)
PP,
