another twin turbo e55 amg is born at BIP
Old Jun 8, 2014 | 06:33 PM
  #201
benzslo's Avatar
C43 5.4, ML320CDI, Fords
I'd be careful dis-assembling that intake. I would first manually fix the runners in the short position to see if it does anything different. Reason I say this is those manifolds are not recommended by MB to ever be taken apart. Many have tried and many have had vacuum leaks after, adding positive pressure won't help anything either.
Not saying it can't be done, but no need to create problems for no reason.
Lastly, makes sure to monitor what your knock sensors are doing. I've seen before problems just as you describe, pulls well initially but gets into the higher band and the power just drops off and often won't even shift to the next gear until you let off the gas. Due to the nature of how the knock sensor works, they can fail and will never set a fault code, but it will most definitely affect performance in the way I just described. Monitor your knock sensor voltage and also your ignition retard when making the pull. I'd first tie those flaps open though if you were previously not controlling them, that will most definitely affect the whole entire upper half of the powerband.
Old Jun 9, 2014 | 11:19 AM
  #202
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Alright, the intake came completely gutted. There are no runners or plates that you guys are refering too.
We are talking to my bro Rbj to duplicate what his intake looks like. I dont see how having any runners at all, or plates can be beneficial other than creating alot of turbulence in the upeer rpm range around 5500-6000rpms. This is where we are having power plummet and breakup again.
Old Jun 9, 2014 | 12:02 PM
  #203
RedBullJnky's Avatar
you to Hate
We are talking to my bro Rbj to try and duplicate what his intake. I dont see how having any runners at all, or plates can be beneficial other than creating alot of turbulence in the upeer rpm range around 5500-6000rpms. This is where we are having power plummet and breakup again.
Just talked to Tony.
Make sure he's got everything.
Old Jun 9, 2014 | 12:10 PM
  #204
chawkins2001's Avatar
2006 E55 AMG
What a baller
Old Jun 9, 2014 | 01:31 PM
  #205
you to Hate
Originally Posted by chawkins2001
What a baller
Not a problem brotha!
Can't wait til we get them side by side
Old Jun 9, 2014 | 03:01 PM
  #206
Bramage's Avatar
F-250
These last 3 posts were a little cryptic?
Any major breakthrough on the horizon?
Old Jun 9, 2014 | 03:04 PM
  #207
September WannaGoFast at Heavens Landing Bring Chad and Nemos sleds up to, they will surprise ALOT of folks up there.
Old Jun 9, 2014 | 03:36 PM
  #208
TTE55's Avatar
05 E55 AMG, 2011 Range Rover Sport SC, 2004 BMW 745Li
Any updated dyno numbers
Old Jun 9, 2014 | 04:07 PM
  #209
No sir, the intake has to come off and we have to get another one, since this thing is gutted.
Another small piece of information is that the kit deleted the factory oil cooler that is normally mounted upfront below the heat exchanger. I wonder how much that effected the oil temps, we may need to add that back into the system too.
Old Jun 9, 2014 | 04:12 PM
  #210
TTE55's Avatar
Text me craig I have the pieces that go inside the intake if you want. Save you a few bucks.
Also, yes the factory oil cooler was removed. The E55 does come with 2, so it may be fine only on one cooler but the larger one was removed. I removed the same oil cooler but went with an aftermarket one to make up for it. I didnt want to just drive around and see if it worked fine with just one lol.
Old Jun 9, 2014 | 04:16 PM
  #211
blackbenzz's Avatar
haters crazy
You didn't take the intake manifold I let you borrow apart did you? I thought you were giving that to Peter to build an intake manifold for you, not use it/take it apart. I was expecting to get it back the same way I gave it to you
Old Jun 9, 2014 | 04:22 PM
  #212
TTE55's Avatar
I have more than one. I had planned on giving yours back like we had originally talked about. In the same condition. You could of just shot me a text.
Old Jun 9, 2014 | 04:23 PM
  #213
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
The intake manifold is set up like this:
There are flaps that essentially open and close making the path longer or shorter. B is longer path, A is shorter path
If your flaps are missing then that could be your issue, air turbulence going in both ways through A & B channels. Seal off one set and your problems will likely go away. Sealing off B would probably help with top end.
Below you can see the brass colored flaps:
[/URL]
These pics are courtesy of link given in a post made by Rocketmullet. Take a look at his link in more detail.
Best of luck brotha!
Old Jun 9, 2014 | 04:29 PM
  #214
blackbenzz's Avatar
haters crazy
My phone is dead. Ok thanks
Old Jun 9, 2014 | 05:24 PM
  #215
Max.H's Avatar
E55
Just my 2 cents. But that stock w210 or w211 E500 intake manifold does not look good to me.. Especially for what you guys are trying to do with it.
I know its easier said then done but, a custom intake manifold or something from the Mopar SRT8 intake manifold would seem like a much better option. It's big and the same shape as the ones you guys are using… Maybe the ports line up too. Or an aluminum adapter should work. Just a thought. GL!!
I think CLS55TT has a superb setup. Very well thought out and it looks and performs great!
Old Jun 9, 2014 | 08:57 PM
  #216
you to Hate
This is what I did. and that's what he's doing.
Old Jun 9, 2014 | 09:07 PM
  #217
2006 E55 AMG
sending you a text paul, thanks to all the fellas.
Old Jun 10, 2014 | 04:21 AM
  #218
turbo97se's Avatar
Nice! I like this forum more and more … people sharing their knowledge with others. There are many that wouldn't.
Best of luck with your project too RBJ!
Old Jun 10, 2014 | 04:27 AM
  #219
JoeNobody's Avatar
Mercedes
The lower oil cooler was not present on early E55's, and was added mid year 2004. So perhaps going without it isn't such a big deal.
Old Jun 10, 2014 | 06:34 AM
  #220
2006 E55 AMG
good point Joe, forgot about that homey.
Old Jun 10, 2014 | 10:19 AM
  #221
Joncl's Avatar
E55
Chawkins why don't you do the same thing as clstt? It's a proven method and works very very well!
Old Jun 10, 2014 | 10:32 AM
  #222
blackbenzz's Avatar
haters crazy
Hope you get this issue resolved. When you get to over 17.5PSI I have a brand new map clamp sitting here I hope you guys find a tuning solution around it because that will help many people
Old Jun 20, 2014 | 11:54 AM
  #223
Bramage's Avatar
F-250
What is the staus of this build? Did you guys give up, or is there behind the scenes R&D going on to isolate the issues?
Old Jun 20, 2014 | 01:17 PM
  #224
No, we know what the problem is Dane. The intake was just pulled off today, and we measured the long runner intake ports. We are having a machine shop cut the appropriate size flaps for each long runner port, so we can weld those on, and seal off the long runners.
Once that is complete, we will force the stock flaps open on the short runner ports, and will be done at that point. Elliott has this setup and it works great, so we dont anticipate any more issues with the intake.
Old Jun 20, 2014 | 11:10 PM
  #225
you to Hate
Good job guys!
