ESP Warning
Hey guys I don't post much but I need help. My ESP warning came on and says take to shop. Any Idea's or help.:nix: Thanks ahead of time for response.
Hook it up to das, if it says speed sensor error, check the wheel bearings
Did you have battery disconnected recently? Try resetting by turning steering wheel all the way left hold 2 secs, all the way right hold 2 secs, then back left hold 2 secs. Key has to be in ignition with car running to work, no keyless go start. This will reset the steering angle sensor, happens to mine on occasion when battery is disconnected.
Originally Posted by shardul
(Post 6124126)
Originally Posted by bstudey01
(Post 6124174)
BTW my car felt like it lost power.
Man I think its my supercharger pulley because as I drove it a crazy noise started, pulled over and it was wobbling quite a bit and noise coming from it.
Have you had your pulley replaced recently? If not, could be just the bearing.
Did you check to see if the bolt is still tight? |
Spoke to brabus k8 last night. Rivets on his oem
stock sc pulley have failed. |
(Post 6124363)
I just want to thank Shardul for helping me out and responding to my panic so fast. Rivets on my OEM sc pulley all failed and got a new one from the man. He took my call late night sent me the pulley and put that thing on in no time and I'm a noob when it comes to these things. Car is back in action and runs great. This smaller pulley makes a difference. Felt it right away. Again thanks Shardul for your help and when I move to Houston at the end of this month I can't wait to have some more things done.
welcome
Text me when you move to Houston! |
