Denroll's 90mm TB inlet
Old Aug 24, 2014 | 01:33 PM
Bramage's Avatar
F-250
I haven;t walked right for a month since the last time I saw Denroll
Old Aug 30, 2014 | 12:28 AM
Denroll's Avatar
'06 E55
Update on some mods:
Needed some airflow to go with this 90mm TB. OEM Y-pipe is really thin. I got this idea from Scoto and made one out of two 90 degrizzle silicone elbows. They are 3.5" to 4". I cut and then epoxied them together. 4 layers of sealant to ensure no leaks at the seams. A monster compared to the stocker:
I dropped off the intercooler at a shop for modification. Had it cut open to remove the baffles; now a single pass core instead of the 80-pass or whatever it was. Also had it tapped for larger fittings. I have silicone tubing with a 3/4" ID that will be run throughout the entire system since the heat exchanger and my Meziere pump both have the same larger fittings. Ditching the labyrinthine stock setup will also help with the flow. Here's the new fittings and hose versus those weaksauce stock tubes:
Look at that mess!
Old Aug 30, 2014 | 12:37 AM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Modified the charge cooler to help cool things or provide less resistance for air?
Old Aug 30, 2014 | 12:58 AM
cm60k's Avatar
Good jooooooob Dennis..
ZAYED,,
Old Aug 30, 2014 | 01:14 AM
BC928's Avatar
2006 E55, Various other German and ‘Murican
Tell us more, please. Any pictures of the modding inside the cooler?
I thought I saw a thread where someone did this with no affect, but the flow may have been an issue as well.
Logically speaking enough flow and volume with a good reservior and even three normal passes in the cooler should remove most of the heatsoak other than at a track setting.
Will you also increase your radiator size for the circuit?
Cost outline?
Old Aug 30, 2014 | 02:54 AM
Denroll's Avatar
'06 E55
Keeping it cooler, is the intent.
Cost outline?
I already have a bigger heat exchanger and i/c pump. Couple hundred dollars to have a shop cut the sides off, grind out the baffles & exit channel/tube/thing, weld it back together, and then tap it for larger fittings. As you can see, they added some extra material around the threads. I had to grind some extra material off of the sides as it has to fit down in the vee far enough for the s/c to bolt down.
I borrowed an idea from Smokey Yunick's playbook. He was an old racecar mechanic who was legendary for finding creative loopholes in the rule books. He once ran a car with a fuel line so long that it held an additional five gallons of fuel. While not that extreme, I ran the hoses a bit long. The bigger hose and extra length will give me a little more capacity.
Old Aug 30, 2014 | 08:25 AM
  #32
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Smokey Yunick - - The true God of combustion ummmmmmmmm
Old Aug 30, 2014 | 09:21 AM
  #33
cij911's Avatar
one car at a time
Denroll - If you want an OEM quality Y pipe made, let me know...Also, I doubt changing the pass through the intercooler will really yield benefits, but I could be wrong. I had a guy that works for me design and build a bigger intercooler (cast unit with new bricks), but it would have been too expensive to bring to market (~$1k). Harry was convinced the stock intercooler is killing / hurting performance and that people could make quite a bit more with his design...
Old Aug 30, 2014 | 11:37 AM
  #34
Bramage's Avatar
F-250
Put that thing back together so I can get these mufflers out of my back seat!!!
Also, I want to see IAT logs!!!
And Track Times...
Your old intake was bottle-necked. You should have much better airflow now. In terms of cooling, I guess we will find out
Looking good!!
Old Sep 2, 2014 | 04:10 PM
  #35
Denroll's Avatar
'06 E55
Update. Was making good progress, then had a "well... *****" moment.
SC/inlet/IC all bolted back together, fresh coat of silver ceramic paint, cleaned off the gasket mating surnfaces:
I have a bench grinder with a wire wheel. Can't resist cleaning some parts:
If you missed it in the other threads, this is a great way to make sure everything is connected and the gaskets are properly lined up. just some threadless rod and vice grips.
It was tighter than a nun's B-hole, but I managed to get both fatty coolant lines and the fuel rail loop to fit under the supercharger. It did involve a midnight rage-quit, but I got it the following morning. Hard to see, but it's all in there:
Experimental Y-pipe fits with plenty of room. No need to use metal shears... yet.
Aaaaand the progress halts.
I'm about 1/2" shy of the clearance needed for the surge tank. Now, I can either take everything back apart, have more material added to the inlet, and tap new holes so I can mount the TB at an angle, or I can just find a way to get more clearance at the surge tank. First instinct was to just wail away at it with a hammer, but that cast stuff would just shatter.
Old Sep 2, 2014 | 04:31 PM
  #36
Forrest Gump 9's Avatar
shrimp boat
Where do they touch? Grind some on each. You're almost there.
Old Sep 2, 2014 | 04:44 PM
  #37
Denroll's Avatar
'06 E55
It touches right above the seam on the surge tank. I'll try to grind some of it and then reinforce it from the inside.
Old Sep 2, 2014 | 04:51 PM
  #38
justinwrock's Avatar
Ducati
My thumb is handsome and photogenic.
Oh my, such a well manicured nail.
Old Sep 2, 2014 | 04:58 PM
  #39
BC928's Avatar
Hindsight 29/20 - should the Thread patterns on the inlet be... What, twisted CW a bit looking at the TB opening? Will this then start hitting the hood?
I am listening very carefully. This and headers would increase the "air pump" nature of the engine package significantly and I think should come before anything else other than proper fuel routing.
Old Sep 2, 2014 | 06:33 PM
  #40
Denroll's Avatar
'06 E55
Yes, it would be ideal to have it rotated 45 degrees, but it will take more material to be built up and then clearance down below around the bypass valve might be an issue. I had to cut away some of the rubber on it as it is now.
My nails are nice.
Old Sep 3, 2014 | 09:25 AM
  #41
Bramage's Avatar
F-250
this
Old Sep 3, 2014 | 10:38 AM
  #42
berti_00's Avatar
2016 Cls63s AMG
Tighter than a nuns butt hole Lmao you kill me man... Anyways looks great as always bro,
Old Sep 3, 2014 | 12:21 PM
  #43
Bramage's Avatar
F-250
Download the app called Grinder.. All your problems will be solved!!
Old Sep 3, 2014 | 12:53 PM
  #44
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
****ing nice JOB. can't wait to read on the improvements
Old Sep 3, 2014 | 05:19 PM
  #45
rockthemullet's Avatar
2005 Mercedes E55 AMG
A half an inch you won't find with just grinding. I hope you get it resolved!
Good call on the threaded rod and vice grips
Looking forward to seeing more out of this
Old Sep 3, 2014 | 08:10 PM
  #46
Denroll's Avatar
'06 E55
Like any good sophisticated redneck, I am well stocked on JB Weld.
Old Sep 3, 2014 | 09:51 PM
  #47
Bramage's Avatar
F-250
Denroll thinks 6" is this long : |--------------------------------------|
So take that into consideration
Old Sep 3, 2014 | 10:35 PM
  #48
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
I had to mount mine at an angle to get it to fit. With 1/4" phonetic spacers under the SC it just touches the foam hood liner.
Old Sep 3, 2014 | 11:07 PM
  #49
cm60k's Avatar
Waaaaaw, wonderFUL job MaaaaaN..
ZAYED,,
Old Sep 4, 2014 | 09:14 AM
  #50
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Got room for a TB spacer?
