Oil cooler lines wyait
Found some oil splashed on the driver's side. Looks like the oil cooler lines but did not confirm where the oil was coming from other than that general area before I broke the coolant hose side of the coolant breather hose.
Which was of course holding back some very hot water, which burned by hand pretty well. So. I'll be replacing the oil cooler hoses and seals just because it's a good best practice. I'll also be replacing the coolant hoses and the reservoir which crumbled when I touched the tank side of the breather line. Germans and their damn crumbly plastic. Question : any other WYIAT for me? I'll be removing the radiator to make some room to get these hoses replaced. Serpentine? Thermostat? Hidden coolant hoses? Need the car soon, but have to order parts anyway, so I can do some work in this area to be sure. So far it's: Expansion tank Upper hose Lower hose Breather line Oil cooler lines Oil cooler line seals against oil bulkheads Maybe longer line from tank to passenger side. I also see a small coolant line that comes from the front of the radiator on the passenger side. The finicky rubber shroud that interacts with the intake holes looks like it would be a good piece to replace as well. Suggestions? |
I have my current parts list:
http://www.mbpartsworld.com/images/p...011.941014.jpg RIVET. Stock Code: 1239900092 $ 1.90 Update Quantity Remove Item $11.40 http://www.mbpartsworld.com/images/p...234.100825.jpg CLAMP. Stock Code: 1709950005 $ 2.90 Update Quantity Remove Item $2.90 http://www.mbpartsworld.com/images/p...039.061019.jpg SEALING RING. Stock Code: 0039971889 $ 5.00 Update Quantity Remove Item $10.00 http://www.mbpartsworld.com/images/p...398.110112.jpg AIR BAFFLE. Stock Code: 2115001516 $ 65.00 Update Quantity Remove Item $65.00 http://www.mbpartsworld.com/images/p...273.111115.jpg RADIATOR HOSE. Stock Code: 2115014482 $ 40.00 Update Quantity Remove Item $40.00 http://www.mbpartsworld.com/images/p...273.111115.jpg RADIATOR HOSE. Stock Code: 2115014482 $ 40.00 Update Quantity Remove Item $40.00 http://www.mbpartsworld.com/images/p...272.100421.jpg COMPENSATING TANK. Stock Code: 2115000049 $ 56.00 Update Quantity Remove Item $56.00 http://www.mbpartsworld.com/images/p...420.110705.jpg O-RING. SEAL RING. Stock Code: 0169972445 $ 2.40 Update Quantity Remove Item $4.80 http://www.mbpartsworld.com/images/p...273.111115.jpg BREATHER PIPE. Stock Code: 2115010925 $ 39.50 Update Quantity Remove Item $39.50 http://www.mbpartsworld.com/images/p...273.111115.jpg BRACKET. Stock Code: 2115040540 $ 2.70 Update Quantity Remove Item $2.70 http://www.mbpartsworld.com/images/p...184.110510.jpg COVER. Stock Code: 2118890525 $ 2.70 Update Quantity Remove Item $2.70 http://www.mbpartsworld.com/images/p...273.111115.jpg RADIATOR HOSE. Stock Code: 2115013782 $ 70.00 Update Quantity Remove Item $70.00 http://www.mbpartsworld.com/images/p...015.090630.jpg HOSE. Stock Code: 2115000275 $ 414.00 Update Quantity Remove Item $414.00 |
