Trans adapter plug replacement ?
Old Oct 11, 2014 | 05:13 PM
hayseed's Avatar
04 e55
I have some slight dripping from the trans adapter plug ,,, was wondering how much fluid will come out and if it's a straightforward remove/replace,,,, it looks like you remove the belly pan and heat shield and then R&R --- is it that easy ?
Thx
Old Oct 11, 2014 | 05:42 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
one 7 or 8mm bolt, plug is about $8-12 and you just need to get underneath the car to change it. SOME FLUID WILL LEAK, so have a quart or 2 ready.
Old Oct 11, 2014 | 05:43 PM
green1212's Avatar
2004 MERC E55
tranny plug
you dont have to actually remove the belly pan. if you have more than 50k miles and the tranny service have not been done, then be a good idea to do it all at one time. but if you have done the tranny service, just remove the plug. very little tranny fluid will leak out when you remove the plug while the belly pan is attached. just be careful with the small screw in the middle of the plug, it doesnt need to be too tight, just snug. feel the force you use to loosen the screw and reapply with similar effort. very easy r&r.
Old Oct 11, 2014 | 10:07 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
This is a recall item .. at least it was on my car. I didn't realize until much later and had replaced myself. Call your dealer to see if the recall work had been done. Also sometimes the fluid can wick all the way to the TCU so you might want to check that also.
Old Oct 11, 2014 | 11:56 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
They are easy enough to swap out.
Ensure the pins and respective receptacles are perfectly aligned before sliding things home as they're quite fragile.
Old Oct 12, 2014 | 02:21 AM
biggking's Avatar
My first impression of doing this job was 'i'm going to eff some stuff up', right up until the part was delivered.
