Question about aftermarket crank pullies.
I just bought an aftermarket crank pulley. 178mm ( I think )
It is the welded type.
I notice there is one crack on the rubber that bonds the inner to the outer.
My question is, when these are made are they made with a new rubber ? or revulcansed ?
I was surprised that something reasonably newish, would have a crack in the rubber.
I did not buy it new, but not sure if I should fit it.
Has anyone else fitted one that has a crack in the rubber ? as the outer band is supported by the rubber I am a little concerned.
Any suggestions would be great thanks.
Personally I would consider a crank pulley pin so there will no chance of the pulley shearing the keyway if anything does go wrong. Maybe have a word to Shardul to see if his kit will fit your pulley. It comes with a reusable hex head crank bolt also. A small investment for peace of mind.
