Only one brake pad sensor on the front?
Old Nov 3, 2014 | 12:47 AM
poohlvhun's Avatar
e55 amg
So I just got a 2006 (aug 2005 production) e55 and went was going ahead and do a rotor/ pads change.
I could not for the life of me find the sensor on the front driver side even though reading through the DIYs that one just unplugs it.
Determined that I just don't know where it is, I switched to the passenger side, lo and behold, the sensor and wire is right in plain sight!
So the question is : is there only one front sensor for 2006 cars that has the cls suspension? Or did my drivers side sensor got ripped off by some dumb mechanic by the previous owner?
Thx!
Old Nov 3, 2014 | 01:21 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Just the one!
Old Nov 3, 2014 | 07:45 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
one on the front and one on the back too.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 3, 2014 | 09:47 AM
poohlvhun's Avatar
e55 amg
Thx for confirming!
