Ran a 10.975
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
Mods....
ECU Tune by eurocharged, 168 kleemann pulley, 84mm S/C Pulley, Belt Wrap Kit, 5 piece idle pulley kit, 90mm TB & custom cold air intake, Fuel rail upgrade, 550cc injectors, Ported Heads, PTE cams, Kleemann Headers, C63 Exhaust, X-pipe, Primary & secondary cat delete, TCU tune by BIP, IPT trans valve body, 3000 torque converter, Kleemann LSD, Split Cooling System/2.5 gallon under hood tank, NGK Colder Spark Plugs, eurocharged HE, Bosch & Meziere Pumps, single pass intercooler, Killer Chiller, Meth injection for cooling
Great stuff and great runs! Congrats on the 10 sec club!
Can you 1.5x guys please tell me what you are doing at the line to get these 60ft times. I think Kevin tried everything and we couldn't get his car to 60ft that 1.5x. Thanks
LOL "Kleeman chinatown specials" Funny, your not the only one I have hear say that. I think that maybe is next mod.
PLATINUM SPONSOR
Very nice! Your car is launching haaaaaard!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#32
Nice, how do you like those filters? Similar intake setup to my fangs setup. I run 3.5" into a 3" y pipe with no inline filter. I have two K&N filters at each side of the radiator (made from a k&n filter for a viper)
#35
Here's a link to jegs but you can get them at summit or spectre themselves
http://www.jegs.com/i/Spectre/865/98...FSgS7AodcwQAgQ
johnny_b (01-19-2017)
#37
Spectre
awesome thank you. Was always thinking about doing a custom intake setup.
#38
The filters work well & the ceramic coating helps minimize the heat.
