ACG W211 E55 & E63 Brake Packages
ACG W211 E55 & E63 Brake Package Upgrades listed below: https://cimg5.ibsrv.net/gimg/www.mbw...0d7a8138bf.jpg Stage 1: Brake Pad Replacement Packages. If your discs are still good, but you need a replacement pad, or a dedicated track set up we have put together these to refresh your braking system for more bite, less fade and most importantly less brake dust. https://cimg3.ibsrv.net/gimg/www.mbw...28fa69288d.jpghttps://cimg4.ibsrv.net/gimg/www.mbw...d796754195.jpg W211 E55 Stage 1 Street Brake Package: $495 + Shipping - Porterfield R4-S Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) W211 E55 Stage 1+ Street Brake Package: $995 + Shipping - Endless MX72 Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) W211 E63 Street Brake Package: $450 + Shipping - Porterfield R4-S Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) W211 E63 Street Brake Package: $875 + Shipping - Endless MX72 Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) Stage 2: Complete braking system replacement packages. These packages will include Girodisc 2 piece floating slotted replacement rotors (drilled/slotted additional $150), your choice of pad compound and Motul Fluid. https://cimg0.ibsrv.net/gimg/www.mbw...19cbd0c17e.jpghttps://cimg3.ibsrv.net/gimg/www.mbw...bc8e84afc7.jpg W211 E55 Stage 2 Street Brake Package: $2,400.00 + Shipping - Girodisc 360x36mm Front 2pc Slotted Racing Rotors - Girodisc 330x34mm Rear 2pc Slotted Racing Rotors - Porterfield R4-S Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) W211 E55 Stage 2+ Street Brake Package: $2,950.00 + Shipping - Girodisc 360x36mm Front 2pc Slotted Racing Rotors - Girodisc 330x34mm Rear 2pc Slotted Racing Rotors - Endless MX72 Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) W211 E63 Stage 2 Street Brake Package: $2,350.00 + Shipping - Girodisc 360x36mm Front 2pc Slotted Racing Rotors - Girodisc 330x34mm Rear 2pc Slotted Racing Rotors - Porterfield R4-S Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) W211 E63 Stage 2+ Street Brake Package: $2,775.00 + Shipping - Girodisc 360x36mm Front 2pc Slotted Racing Rotors - Girodisc 330x34mm Rear 2pc Slotted Racing Rotors - Endless MX72 Front and Rear Street/Track Brake Pads - Motul RBF 600 Racing Brake Fluid (2 500ML Containers) Girodisc 2 piece rotors are a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. Girodisc rotor replacements have shown a significant weight reduction in the form of up to 7-8 pounds per corner. That is a potential total decrease in unsprung weight of up to 30 pounds! This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response. The central hat section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. As opposed to the OEM disc, these rotors are side specific featuring a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc, venting properly and cooling the brakes efficiently. The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads. When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors. |
how do they compare to RacingBrake rotors for the 63?
Originally Posted by baldmike73
(Post 6314071)
Personally I like the look of the Girodiscs myself but that's all personal preference. |
How much are replacement disks?
Originally Posted by 211.070
(Post 6314215)
sweet deals
Thanks guys, bump it up for some stoppers. Contact me if you need anything.
Bump!
Have anything for these bad boys? Something that has less dust?
I wish the Stage 2 package offered drilled and slotted rotors
Originally Posted by slownrusty
(Post 6320259)
Originally Posted by sack5000
(Post 6320246)
(Post 6320259)
Originally Posted by O-55
(Post 6320426)
They're offered under the "Stage 2" section for an additional $150.00.
Bump for some brakes. Let me know if anyone has inquiries or questions :)
Do these kits come with upgraded brake lines? I see brake lines in the pics.
Originally Posted by mrweelr
(Post 6348834)
Sorry the pics taken by me are generic and specifically shown are for the W204 C63. Regardless we can get brake lines for these cars. All the best. |
What would you recommend if the rotors are still good but want to replace pad with less dust? on 04 E55
Originally Posted by E55Vroom
(Post 6349412)
I'm sure everyone here would agree these are some of the best street pads for these cars. |
Originally Posted by Tal@ACGAutomotive
(Post 6349953)
It's really tough to beat Akebono pads. Super low dust, very quiet and much better bit than stock.
Tal - running any specials for Akebono front pads?
(Post 6350875)
Bump still running this deal on brakes :)
Pm sent!
Bump for stoppers :y
Bump for Euroteck E55 diffuser?
Free Bump - LOVE THE GIRODISCS on my wagon - the pads take bit of time to warm up but no fade and def less dust - wish it came this way from the factory - plus they look pretty - LOL
