E55s with Meth Pump in Fender
Has any W211 E55 owners installed a meth pump inside the front passenger fender, beneath the washer pump (like post 79 in this thread https://mbworld.org/forums/w211-amg/...ethanol-4.html)?
I ask because when I tried a test fit the pump would bulge out the fender. I know others have - non E55s - but curious if any E55s have does this pump fender install. Thanks ahead for any response.
I mounted mine close to the washer tank in my 05 E55. If you remove your fender liner there is a spot big enough for the pump where the liner meets the plastic floor tray.
2005 E55 AMG
Scoto and boostedfe3, when you mounted it at your location...did you mount it horizontally or vertically? I having a hard time visualizing it.
I got a pic
I will find it
I put it near the front bumper for easy access in case you need to change pump etc
I will find it
Question on the tank
I was going to omit the aquamist level sensor completely since there's a factory sensor, but I believe the HFS may use their sensor as one of the failsafes in the controller. If anyone knows if you can run without it I will gladly omit having to have it installed.
