Trunk tank install is beginning!
8 Attachment(s)
I finally received the reset of my hardware for the kit. I was not too impressed with the fittings, and line that came with the kit. So, I bought 50' of -12 black nylon braided line, and all of the fittings to make it happen. I will be using bulkhead fittings to get the feed/return lines in/out of the trunk area. I will update this as I make more progress.
Attachment 390301 Attachment 390302 Attachment 390303 Attachment 390304 Attachment 390305 Attachment 390306 Attachment 390307 Attachment 390308 |
4 Attachment(s)
I thought that I was going to run the lines out of the front of the trunk, but I decided that going out of the back was the best option. Trying to connect to the bulkhead fittings with hose ends would be a real nightmare going out of the front.
The tank is mounted, and the bulkhead fittings are in place. Hopefully I will have time this week to run some line. I will be running the 90 degree fittings outside of the rear of the trunk. With the -12 line being able to handle a 4.5" 90 degree bend radius I will not require additional fittings! Here is the tank in its mounted position, and the bulkhead fittings as well. Attachment 390278 Attachment 390279 Attachment 390280 Here is the branding of my trunk tank! Attachment 390281 |
1 Attachment(s)
here is the tank i built... very nice to go to the track, ice it down and have the best performance possible... i have a rule 2000 in the tank and a meziere 136 up front...
Attachment 390277 |
Looking good! Interested in the -12 routing....
I'm about to start my install, too. I just don't have as much room to play with since it will have to share the space with my methanol tank.
had mine for over 2 years and the only problem is the rule 2000 pump always dies every few months. what are other doing about this ? the rule 2000 is a blige pump not meant to be ran constantly. it is super strong flowing though while it lasts.
Originally Posted by 211.070
(Post 6388628)
http://i78.photobucket.com/albums/j1...pspqk9xgbb.jpg http://i78.photobucket.com/albums/j1...pscjfrcg1v.jpg http://i78.photobucket.com/albums/j1...psdjl6mpmi.jpg http://i78.photobucket.com/albums/j1...psj2yakhve.jpg http://i78.photobucket.com/albums/j1...psrox1wp1j.jpg http://i78.photobucket.com/albums/j1...ps36mwueyu.jpg http://i78.photobucket.com/albums/j1...ps0fhyiy3g.jpg http://i78.photobucket.com/albums/j1...psrnywx2xt.jpg |
Originally Posted by AMG E Power
(Post 6390303)
Originally Posted by Hammer Down
(Post 6390307)
I've had my rule for about 3yrs and no issue yet but even if it does die the Mezeire is strong enough to run the whole system
(Post 6390483)
do you have the rule 2000 pump wired to run all the time ? as in if I just press my push start button one time it starts running.
Hammer, I am in the process of adding a tank as well. I have a rule 2000 to install and thought of ditching the 5 yr old CM-30, or should I replace it with a Mezeire136?. Eventhough the flow rates are way different, does the Mezeire take some of the load off of the Rule and allow it to last longer?
(Post 6390307)
(Post 6390483)
Do you have your stock pump in place or only the rule in tank? |
Originally Posted by RaceHorse
(Post 6390715)
Are two pumps necessary??? It seems kinda common. Do you have your stock pump in place or only the rule in tank? |
@racehorse I have the rule 2000 pump and the bosch 010 pump up front.
(Post 6391078)
Two pumps = maximum flow and two pumps will also act as a fail safe. I have run the Mezeire by itself and I have run the Rule by itself so as I stated before if one happens to stop working you will be ok. Exotic-Metal (Brooke) came up with this setup like 5yrs ago while running a standing mile event and it's been the ticket every since. The only thing really to decide is how big of a tank you want to run. Standard as pictured above or have a 5 gallon tank made.
I ran a Mezeire up front (w/EC HE) and Rule2000 in tank (3.5gal) and a Cobra HE mounted under the trunk that held 1.2gal. The Mezeire took a dump on me while I was at MIR and the Rule2000 maintained flow. I ran a best ET of 10.7 that day. |
Thanks guys, I ordered a Meziere this morning, hope to have it this weekend to run along with the in tank Rule. Sorry to thread jack the OP.
any pics of the cobra HE installed under the trunk???
1 Attachment(s)
Attachment 390230
Keep this thread goin, I got my tank and am figuring out how to install it, its cool to see your set-up :y |
Originally Posted by draggbody
(Post 6392183)
Do you guys run coolant in there as well, or just water? I'm worried about the water rusting.... thoughts?
3 Attachment(s)
(Post 6392183)
Attachment 390144 Attachment 390145 |
Originally Posted by C_DirtyTwo
(Post 6395744)
(Post 6391078)
Originally Posted by RedBullJnky
(Post 6395855)
http://i1114.photobucket.com/albums/...y/ecd0b12d.jpg
http://i1114.photobucket.com/albums/...y/c8e47f5c.jpg http://i1114.photobucket.com/albums/...y/9fb0f903.jpg |
1 Attachment(s)
(Post 6398218)
how did this look from outside the car?
Attachment 390021 |
best place to hook up the 12v pump in the trunk ?
