Fog light question
Fog light question
Hello, I switched out to led lights for the fogs from having hids and now I only have 3.50 volts. The fogs before were hids and they worked fine. Anything I'm missing to why I only get 3 volts?.. Thanks for the help
Edit... Never mind got it.... Thanks
Very likely the injectors.
Get the thoroughly cleaned.
I had misfire issues plague another car of mine. Nothing no amount of cleaner or additives helped it. Only thing that works was changing it out but that care had nearly 400k miles on it (Prius).
Your R wont have as many miles and a good specialized cleaning should do the trick it is indeed the problem.
