wheel fitment question plsssssss
Old Mar 21, 2016 | 01:49 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
Bolt pattern: 5x112
Front: 19”x10” – ET: 35
CB: 66.6
square set up ... would this be ok on our car? what size front tires would you run ??
Old Apr 10, 2016 | 05:02 PM
Ruthle55's Avatar
e55 amg
As you probably know, You're going to need a spacer to clear the large hub bore somehow. Depending on wheel. 19x10 will work. Im at 18x9.5+25 and it fits fine.
Old Apr 11, 2016 | 12:41 PM
DiegosAnotherR1's Avatar
e55
Doesn't our cars have a 66.6 center bore? So the center bore of the wheel should not be a problem.
As far as if 19x10 +35 will work, I am not sure. I have 19x9.5 in my rear with a 265 tire with no issues. But I do not know the offset.
Old Apr 11, 2016 | 01:03 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Yes
Old Apr 11, 2016 | 01:08 PM
dchl21's Avatar
thanks guys... I wont be running those size anymore
Old Apr 11, 2016 | 02:29 PM
dchl21's Avatar
however if you want to help me out then ..... the new wheels I got Im not sure what spacers ill need ... im going to test mount and figure out but lets guess what I need so I can source parts.
front
20x8.5 et45
245/35/20
im guessing a 15mm to bring me to flush ? I do have a set of 12mm for front
rear
20x9.5et45
275/30/20
15mm or 20mm ?? 20mm sounds really big.. either way I don't have any rear spacers
would these even mount and clear bbk without spacers ?
also where do you guys buy spacers ?? I like h & R but they always come with uglyass bolts.
Old Apr 11, 2016 | 03:44 PM
Ruthle55's Avatar
e55 amg
Thats not the issue. The issue is, wheels that are wider, with a slightly higher offset, don't have much meat on the back pad of the wheel itself. The hub bore on an e55 is like an 1" long or something WITHOUT the dust cap. Something like that anyways. So, you need a wheel with a thick enough back pad, or spacers, to give yourself room. Everyone cries about not running the worthless dust caps. IF you have center caps, its not much different anyways.
I sourced my spacers from a place in Las Vegas. And no one can answer how flush you'll be because the desgin of the wheel itself takes a big role in fitment. Which im sure you already know.
