Has anyone put these EXACT rims on your w211 AMG??
Old 04-09-2016, 02:47 PM
Worth the wait's Avatar
2006 E55
http://www.ebay.com/itm/231675690605?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I go through rims like chewing gum here in the DMV
I like these rims and they seem nearly identical to a set I got from Sonic Tuning that he no longer sells, so I would have spares
Seller say as they may need spacers for the brakes.
ANYONE RUNNING THESE RIMS FROM THIS EBAY SELLER?
Thanks guys!
Old 04-09-2016, 11:51 PM
lost_wave770's Avatar
soon to be '04 e55
Originally Posted by Worth the wait
http://www.ebay.com/itm/231675690605...%3AMEBIDX%3AIT
Thanks guys!
Check out powerwheelspro.com, I have a set just like yours for the dmv area, and the wheels have treated me well. I would recommend spacing the wheels to equal a 30mm offset, gives my e55 perfect flush fit.
Worth the wait (04-10-2016)
Old 04-10-2016, 06:01 AM
2006 E55
Thanks for the heads up!
I wasn't aware he had these in 19, used to be only 18 & 20.
You're running the 19"s and using 5mm spacers?
Which spacers?
Thanks man!
Old 04-10-2016, 09:35 AM
951turbo's Avatar
O3 & 05 E55 Alabaster White
I have them on my car and really like them.. No spacers at the moment. Purchased them from USA rim in San Diego CA.
Old 04-10-2016, 11:20 AM
2006 E55
Those look great!
Do they have the Amg logo in them?
Old 04-10-2016, 01:23 PM
soon to be '04 e55
Which spacers?
Thanks man!
They sent me et45 wheels by mistake, so I convinced then to send me 15mm spacers to bring front and rear to et30. Front is 19x8.5 rear is 9.5, and wheels sit flush. And they have the amg logos.
Old 04-10-2016, 04:40 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
they look different than the discontinued ones you were talking about
Old 04-10-2016, 11:42 PM
951turbo's Avatar
Thank you so much, yes they do. Here's a couple more pics
Old 04-17-2016, 02:49 PM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Perfect fitment bro
Old 04-18-2016, 09:38 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Looks good. What size tires are you running?
Old 06-24-2016, 03:48 PM
Reece_MB's Avatar
09 E550 Prm1+Sport 2003 E500 (SOLD)
Running these exact wheels ... different ebay seller, but I think they are exact match. I found them to have a lot more blue than I would like, but otherwise a good wheel. Here's the thread if you want pictures:
https://mbworld.org/forums/w211-amg/...t-pics-44.html
Old 06-24-2016, 07:49 PM
bierry's Avatar
E55
I recently bought these exact wheels from this seller, except wanted all 4 in 19x9.5et35 but no price difference. They are indeed much more blue / teal than he pics in the listing.
Comes with chrome center caps which I asked for silver ones at no addl charge. The accompanying 'AMG decals' are also noticeably shorter than the slots on the rims.
Last these use 28 or 27mm shank conical style lugs, cannot reuse stock MB radius seat lugs like my other aftermarket wheels, which listing does not state.
Attached Thumbnails Has anyone put these EXACT rims on your w211 AMG??-image-5978273.jpg
Old 06-24-2016, 10:09 PM
BagMan's Avatar
Are you running 19x9.5 all around? If so, what size tires?
Old 06-24-2016, 10:26 PM
bierry's Avatar
E55
Yes, 9.5 w/ 275/30 RE-11s square setup, no rubbing on a stock car.
Depending on tire model you MAY be able to squeeze 285s up front with a minimum 5mm spacer (to clear inside suspension components) but tires whose section widths run wide like the RE71 may simply not fit. 285s on rear will fit w/o issue w/o spacers. I chose the preferred size for 9.5 thus 275.
Old 06-24-2016, 11:44 PM
Reece_MB's Avatar
Looks like I need to remove a wheel and check the lug fitment. I had the local MB dealer install the wheels/tires and they didn't say anything. I'm sure I have the exact same wheels, just different seller. Mine also came with chrome center caps and AMG decals that are shorter than the slots. I had new silver center caps in my old wheels so I transferred them.
Old 06-25-2016, 12:34 AM
bierry's Avatar
E55
Yep, we have the same wheels:
My shop also didn't notice until an oem lug fell off a week later. Inspecting closer it's obvious the radius seat was contacting only the top rim of the bolt hole (paint on rest of the hole seat untouched)
Emailed the seller who confirmed conical bolts are needed. With conicals, finally the paint in the bolt hole stripped evenly indicating proper seating.
Old 06-25-2016, 09:31 AM
BagMan's Avatar
Cool. Got a pic of the fronts on the car?
Old 06-25-2016, 11:54 AM
bierry's Avatar
E55
Old 06-27-2016, 06:45 AM
forcefed4door's Avatar
05 E55, 06 Audi S4
I have the same wheels also. They are really good quality for the price. Don't depend on the amg sticker staying on. It's actually a bit corny, because it's obvious there not real having a stamped logo. Def. good buy though, no spacers needed.
Old 06-29-2016, 06:20 PM
Reece_MB's Avatar
Got some conical lug bolts coming... 14x1.5 28mm shank ... figure the extra 3mm won't be a problem. If anyone finds this wheel with the correct OEM color please post it up! Would be great if Sonic Tuning brought back the ST181 as the color seems to be much closer to OEM.
Old 07-06-2016, 04:43 PM
Reece_MB's Avatar
I wrote an email to Sonic Tuning about offering the ST181 again. Here's what they said: "If we can get 100 set signed up we can offer it again."
I doubt we have 10 people interested in the wheel. haha!
Old 07-06-2016, 06:38 PM
LNDMISSL's Avatar
E55 W211, G55 W463, 2010 GT500, 2008 S4 Cab (Wife), LR4
+1
Old 07-08-2016, 11:17 AM
Reece_MB's Avatar
I wiped the decal slots with rubbing alcohol, centered them up and stuck them on. They look fine, but as soon as I lose one I'll probably remove the others. I've been through the car wash and they stayed on, so maybe they will last a while. I do like the look of the decals on 951Turbo above... but I have to agree they are a bit cheezy on my wheels since they don't match up with the slot. I'll post a pic later.
Old 07-11-2016, 02:05 PM
Reece_MB's Avatar
Old 07-13-2016, 09:32 AM
BagMan's Avatar
Are these wheels concave at all?
