Defrost vent stuck open
The passenger side Front Defrost vent is stuck open. That reduces the AC that comes through the other vents and causes condensation on the outside of the windshield.
I am not a huge DIYer on this car. Any ideas on how to unstick it without going to a shop? AFAIK, it has been this way for 9 months. There are no error codes because several shops have done complete STAR reports. I never told the shops about it because there were more pressing issues at the time.
I have tried switching back and forth from defrost to the other vent options repeatedly.
Minty Fresh (08-09-2016)
Looks like I'm keeping that defrost vent open...
All of the other possible options (pods?) also require removal of the dashboard, so hardly worth it.
That's the crappy part of the blender motors going, the whole dash has to come out.
Hey greaser is there a manual way to turn the blender door without taking out the dash?
This same thing happened on my CLS55. I had a great mechanic (Wade - European Specialists) try every trick in the book short of pulling the dash out to replace one of the nine or so actuators that control the flow. He managed to reach under the dash and manually close one of the defrost vents permanently (I live in Florida, seldom needed) which forced the flow through the AC vents on the dash.
The parts weren't expensive but I really didn't want my dash yanked out. They never seem to go back as tight as they came out. Fortunately, it was on the passenger side.
Must be a common issue, mine is doing the exact same thing. Passenger side as well. 2006 E55 here.
Just thinking about this again. What if some sort of plug were fashioned, say out of foam, that could be inserted into the dash defrost vent on the passenger side. I believe the vent is sealed from the heater box under the dash right up to the outlet at the base of the windshield. Wouldn't that serve the dual purpose of both stopping the super annoying buildup of condensation on the windshield, and also stopping the air conditioned air "leak", making the dash vents blow stronger and more effectively?
Assuming this can be done in a way that is visually acceptable or invisible, this may be the answer to the problem.
I can't begin to imagine how many thousands of dollars the dealer would get to remove and replace the dash, let alone make the repair once they're in there.
Thoughts on this, anyone? In a VERY quick Google search on this exact problem, I turned up three others with the exact same issue, all on the passenger side. Obviously, there's a problem.
Has anyone actually done or had done the repair on this?
Received 1,483 Likes
This place is a joke.
What happens is the stop in the case breaks and doesn't allow the motor to learn it's position. To close the vent manually you'd have to remove the motor and close the flap by hand. I've never tried it with the dash still installed, maybe you can remove yhe glovebox to get at it, or it may be the motor that is sandwiched between the 2 case halves. It's been a long time since I've done one.
The following 2 users liked this post by E55Greasemonkey:
Hulk (08-11-2016),
Minty Fresh (08-11-2016)
If our cars had a normal AC system it wouldn't matter much but in South Florida, my AC struggled to keep the car somewhat cool.
Here in hot humid North Carolina, I might pick my next car based solely on the AC system instead of driving and handling.
This is a notoriously weak AC system. My sister has a top of the line Audi sedan, and when I was riding with her she cranked it up to demonstrate it's full potential. Huge blasts of cold air were rushing out of the vents. Very impressive.
I was told it was a trait with European high performance cars but my wife has a BMW 1M and after a minute or two, I have to back off the AC because its so damn cold. A few of my friends have other M series and Audi S series and none of them have this problem.
Minty Fresh (08-13-2016)
Someone found that the inner lining of the low pressure hose collapses so the pump can't suck refrigerant very well. I wonder how common that is?
The air itself is cold, but the highest setting on the fan seems weak. On a six hour drive to Atlanta in June, the air kept getting weaker and weaker, but I finally figured out that the coils were freezing up. Once the car sat for an hour, it was back to normal.
I have double pane IR and UV reflecting windows and window tint. Those help the AC a great deal. Without it I imagine it would be pretty though keeping temps down in extreme heat.
I have this problem on both my E55 and SL65. I suspect the same parts in both. Right half of the windshield has condensation. Annoying, but not worth pulling the dash.
Minty Fresh (08-15-2016)
