New to me E55, have some issues and questions.
5 Attachment(s)
So while my 2012 CL65 is away getting all the go fast mods done I bought a super clean 2002 Corvette to play with. Well to make a long story short a buddy loved it and traded me his 2003 E55 straight across. Love the car but it has a few issues. It does have some modifications and has the SC crank pulley, long tubes, full custom exhaust, carbon spoiler and lip as well as diffuser, CLS wheels, new air suspension all the way around, larger supercharger heat exchanger, trunk mounted ice box and larger cooler pumps. Has a few other things but I forget what they are right now. Says car makes 55Xrwhp and 700rwtq which I dont doubt as it just waxed my buddies modded 03 Cobra as well as a few other cars I know my modded RS6 could not beat.
At any rate I have a few questions. 1. He said there is a throttle body replacement that can add 30ish HP. Is this true and where do I get it and do I have to do anything else to the car to make it work? 2. Is there a way to link all 4 temp buttons so the driver control changes all at the same time? 3. There is a hose sticking out of the back of both heads thats T'd together and then just is open above the passenger exhaust. When I get on it oil drips on the passenger exhaust and that cant be right so where is it supposed to connect to? I saw a small filter in the trunk that had oil on it and its fitting fit the hose so I put it on it and raised it above the heads thinking it must be a breather and was changed so it does not suck back into the intake. I would like it to be proper though so looking for suggestions. 4. The alarm does not make any noise when arming or when using the panic feature. Is this the siren issue I read about and need to replace that siren behind the front passenger tire under the splash shield? 5. The buttons on the front of the seats seem to do nothing. It does not have the dynamic seats and no manual so I assume they are lumbar and bolster control. I hear a pump run but feel nothing happening. Is there a common issue/fix? 6. I assume the radio does not have bluetooth and wondered whats the best (if any) add on module for that. I hit the phone button and it says there is no phone connected but I see no menu for connecting via bluetooth. 7. The windshield washer tank appears to leak SOMEWHERE. Not sure where but that was the cars only error and when i filled it about 20 minutes latter I saw a puddle start to form nearly dead center at the firewall level under the car. Again, is there a common issue here before I just pull it all apart? I would probably never use it and if the leak isnt in the bottle itself I would probably just unplug the level sensor and dead short it. 8. Its a German car and has the speedometer in KM. I know it has a digital readout in US miles but is it a big deal to change the cluster to an American version? I have a shop and an Autel Elite system so I can program pretty much anything but have yet to work on a Benz. I appreciate all and any help. Here are some shots of my new toy. :) Attachment 365582 Attachment 365583 Attachment 365584 Attachment 365585 Attachment 365586 |
You got the better deal on that trade IMO. I am not a fan of the 2000 era vettes though. How many miles on the car?
86k
You won on that deal. Nice looking E55 bud.
Kind of looks like Shardul's ex.
LaserSVT, pm me your email address so I can send you some info.
Originally Posted by MTV10
(Post 6918507)
Monday bump for a good dude with an awesome CL build going on and active in the 216 section.
I'd help if I could, but I have a '63 and can't add much on the technical issues of the '55's. Looks like a fun gas station....... |
I'll take a stab at answering a couple of your questions:
#1: The 82mm TB upgrade. You will need an adapter, or a SC snout that has been machined to accept the larger TB. I think this one also requires a tune (not sure about that though) #3: That hose connects to each valve cover, and into the driver's side of the big rubber intake hose. If you pull your airboxes you can see where it has come unhooked. If this is the first time you've removed the airboxes, try not to break the BOTTOM clip that holds the Y-pipe onto the TB. You can't see it, but it's there and is easy to break off. |
Answer to question no 8. If you buy a used cluster in Mph you can swap the PCB from the Kmh unit to retain the mileage
http://imagizer.imageshack.us/v2/xq90/268/dsc00428d.jpg |
