Measuring Supercharger clutch gap
Old Sep 23, 2016 | 07:31 PM
Hotsauce55's Avatar
2005 E55
Could not get .36 to fit. Too tight.
Did I measure in the right place and should I do anything given the measurement?
Old Sep 24, 2016 | 02:31 PM
Elhonaz's Avatar
W211 E55 2003
measure between magnetdrum and pulley friction plate. Should be .35-.45mm
Old Sep 26, 2016 | 06:59 PM
Nor Cal SL55's Avatar
2012 E63 AMG
There will be some variance when the pulley is spun. Better tight than loose IMO. If the gap is too great, the clutch pulley springs will work harder and are more likely to wear more (and break) over time. Get a LM21 scattershield for safety.
Old Sep 27, 2016 | 09:14 AM
Hotsauce55's Avatar
2005 E55
Forgot to upload pic!
Old Sep 28, 2016 | 08:09 AM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Also make sure your using Mm and not inches. And yes as you spin the pulley the gap will vary. Keep the largest under .5 mm and you will be fine.
Old Sep 28, 2016 | 11:20 AM
Hotsauce55's Avatar
2005 E55
Gap doesn't seem to vary much & the .36mm is tight
Old Sep 28, 2016 | 12:32 PM
V-AMG's Avatar
2016 E63s Wagon - CCB & CF package
You may close but ok. I just installed my pulley and I can fit the 0.35 and 0.45 gauges in but not the 0.50. 0.45 is tight, 0.35 goes in ok.
You can also start the car and try to lightly apply pressure to the magnetic clutch. If you can easily stop it while the pulley is turning, i'd say you are OK.
Or with the car OFF, turn the magnetic clutch and listen closely whether its scrapping against the pulley.
Do these "tests" at your own risk! Gloves are a good idea. Clutch gets hot and trying to stop it can burn. I usually use a microfiber and just apply pressure with 2 fingers and it stops.
Old Oct 3, 2023 | 03:03 AM
J R's Avatar
J R
e55
Redirecting an old thread I know, but I can't locate specific reference as to how far the feeler gauge has to go into the gap to get the reading. Is it just at the very "outside" of the gap e.g feeler gauge goes in 1 to 2mm, or is it 30-40mm?
Old Oct 6, 2023 | 12:51 AM
ls1_mast's Avatar
w220 S55 AMG 2004
it shouldn't matter .. the gap should be equal since the supercharger pulley is parallel to the magnetic clutch so measure it from any place ... if your gap is not equal ( which i doubt) then you have a much bigger problem...
Old Oct 6, 2023 | 01:02 AM
J R's Avatar
J R
e55
Thanks, after seeing it once I took the pulley off you're bang on. I took the plunge and pulled the pulley as the gap was around .55. Only 2 shims left, removed one, 50/50 likely I'll need another removed. Bearing good.
Old Oct 6, 2023 | 01:12 AM
ls1_mast's Avatar
w220 S55 AMG 2004
since you are removing ( NOT ADDING) i will go ahead an assume that you are talking about the stock supercharger pulley.
keep in mind that once you upgrade your supercharger pulley , you will most likely need to add more shims when the pulley gets older. so keep those shims in a safe place.
Old Oct 6, 2023 | 02:30 AM
J R's Avatar
J R
e55
Yep stock pulley, 221k kilometres travelled. Ive kept the shim I removed, I can only assume there were 3 to begin with.
Old Oct 6, 2023 | 03:22 AM
ls1_mast's Avatar
w220 S55 AMG 2004
i am not sure, since i have seen cars with 3 and others with 4 . however , they are not all the same thickness , keep that in mind
Old Oct 11, 2023 | 03:43 AM
J R's Avatar
J R
e55
Seems like the sc is engaging better, still a slight chirp but from what I've learnt it's not going to go away completely especially on a car this long in the tooth. What is concerning is it doesn't seem to be that quick. FWIW I've a 2003 Audi c5 rs6 @ 204k km (stock) and a 2006 Audi D3 S8 (stock) @ 140k km. Both feel much healthier, but both are lower on the torque side of things (on paper).
No errors on the dash, no smoke, wonky idle etc. I'll try to time the 0-100kmh but it just feels slow.
Old Oct 11, 2023 | 04:49 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Time it with something like a Dragy, and then you will know indeed. Also time the 100-200kmh times please
