Brake Service Questions
I'm about to install new pads and rotors all the way around and while I'm at it I should do a brake fluid flush. Is there a DIY anywhere showing how to do a flush? I have STAR so I should be able to do the same thing as the dealer, but I've never done one of these systems before. Any advice?
in addition to star you also need a motive power bleeder (can purchase on amazon for about $50). when you go into star it does an easy step by step procedure of bleeding the brakes. You will need around a gallon of brake fluid to fully bleed the system. you also will want to hook the battery up to a battery charger while you do it as it will use a lot of battery actuating the SBC unit. Might even want to buy an extra gallon of fluid in case things go sour midway through (they did for me and I had to restart all over again). There are 2 bleeder screws in each front caliper (as one is used to bleed the emergency backup braking system), but star is very specific about when to open which bleeder screw.
The Dot 4 brake fluid MB uses is supposed to be changed every 2 years. Dot 4 has a higher boiling point vs dot 3, but absorbs more moisture. This is why the service interval is only 2 years. If the brake fluid gets hot, then the water will evaporate/boil out and then where the water was in the brake fluid there will just be air and air does not stop hydraulic brakes.
The amount of fluid SDS uses is unreal. Be prepared as Carguyshu states. Even though I have STAR, I instead just use the Motive at the reservoir and a vac bleeder at the caliper. Works well and is more efficient.
JoeJErnst (02-27-2017)
