w211 radio cutting in and out every 5 minutes
Old Mar 12, 2017 | 02:36 PM
65cobra's Avatar
2006 e55
Update: Fixed! I cut out the navigations cd drive with a fiberoptic loop, thanks guys!
I just bought a new to me e55, so I am sorry I will be bombarding with a few questions
my stereo cuts out for 1-3 seconds every 5-10 minutes. the screen does not flash. sometimes it happens with a high pitched squeal especially when in AUX mode. In FM mode it just goes quiet for the same 1-3 seconds
also sometimes when it comes back on not all the speakers work, then it will cut back out and in and they will all work.
I kind of think it may be the amp but, thats just my guess.
I also have the battery protection warning that some convience functions are limited that toggles on and off.
Old Mar 12, 2017 | 02:43 PM
verminator's Avatar
2010 E63AMG
Sounds like it may be time to change out your auxiliary battery. It is up front passenger side on the firewall underneath the cabin air filter. It's primary purpose is to be a back up for your sbc breaking system but when they start to go you get the convenience features disabled message. Uncover it and check the voltage and go from there. GL.
Old Mar 12, 2017 | 02:56 PM
65cobra's Avatar
2006 e55
hopefully thats it I just posted another thread, its an ever ready battery probably from walmart I could not find a date code on it but it has 12.5 volts when its disconnected and 13.95 when its connected and the car is at idle. it seems to be okay. the trunk battery is most suspect its at 12.18 disconnected and 13.88 when connected at idle.
Old Mar 12, 2017 | 03:25 PM
verminator's Avatar
2010 E63AMG
Those numbers sound OK. Did the car sit for a while before you bought it? Maybe just charge them up. Other things that will silence the radio are the telaid being inoperative, also gives you a message on the display. The car is sensitive to the battery voltages, so if it sat and they discharged the issue may go away..?
Old Mar 13, 2017 | 04:43 PM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I had this problem and it turned out to be the factory bluetooth. I just removed the BT module from the MOST ring. It's in the trunk.
Drove me crazy for months. Replaced the head unit, amp, nav but it still happened.
If you don't have the factory phone & bluetooth, forget everything I just said.
Good Luck!
Old Mar 14, 2017 | 12:18 AM
65cobra's Avatar
2006 e55
I am thinking it some short in the system, it does not happen when I am parked just when I am driving
I replaced the big battery today still same error code so I don't think its anything to do with that.
how do I take stuff out of the most ring, the sirius box was not bolted down and was flopping around..... I don't need the nav stuff either.
ok I found a fiber loop, for $8 on amazon Ill start skipping stuff and see If I can find the culprit
Old Mar 14, 2017 | 01:29 AM
Rocman8's Avatar
E55
Start with software updates on the comand and audio gateway. Fixes 90 percent of them. Go to a dealer and have someone do it that's done it before.
Old Mar 14, 2017 | 11:36 PM
65cobra's Avatar
2006 e55
I think my next step is waiting for the fiber optic loop to come but while searching the headunit on car-part using the vin search my current headunit is not listed as one of the options, could that be part of the problem?
here is a pic of the tag
Attached Thumbnails w211 radio cutting in and out every 5 minutes-20170311_175134479_ios.jpg
Old Mar 17, 2017 | 01:35 PM
65cobra's Avatar
2006 e55
Fixed put a fiberoptic loop in the nav, cd player in the trunk and it stopped cutting out. on to the next things.....
Thanks for all the help
Old Feb 24, 2018 | 12:07 PM
Lee Gregory's Avatar
2006 E350 4msticwagon
Do you have a photo of how you did that? Thank you
Old Feb 24, 2018 | 11:44 PM
65cobra's Avatar
2006 e55
I dont have a pic but basically i unplugged the nav cd player fiber optic wire and plugged a loop into the fiber optic cable. so essentially I bypassed the nav.
Amazon Amazon
Old Mar 4, 2018 | 03:10 AM
mondo's Avatar
Alfa Romeo Giulia Veloce
This just started happening to me this weekend. so frustrating! this thread will be very helpful, thanks.
Old May 4, 2018 | 10:56 PM
scott099's Avatar
E500
I'm having the same problem! happens ONLY when I'm driving the audio will cut out. doesn't matter if its radio, cd, cdc. if I'm parked the audio runs non-stop no problem. glad I found this thread and hope that loop fixes mine too
Old May 6, 2018 | 06:38 AM
mondo's Avatar
mine has actually stopped doing it. absolutely no idea why?
Old May 8, 2018 | 04:14 PM
scott099's Avatar
E500
I'm happy to report this fixed mine too!
I installed the fiber optic loop bypass on the navigation, no more cutting out! before it would cut out almost exactly once a minute only when driving. it didn't matter the source - radio, cd, cdc, didn't matter the volume or anything else. just when driving. immediately after installing the bypass on the nav the audio will play non-stop again.
Thank you so much!!
Old Jan 15, 2020 | 01:03 PM
Sphinx144's Avatar
2006 E55 AMG, Alfa Romeo Stelvio Ti Sport
Thank you so much!!
So by bypass you mean you got rid of the navigation and now it no longer works?
I'm having problem with my navigation not finding satellites and I'm guessing because of that I'm also experiencing this issue you guys describe in this thread.
UPDATE :
I did the bypass as indicated here, everything Works perfectly now except no more navigation.
Old Jan 16, 2020 | 04:53 AM
mondo's Avatar
well there's a coincidence i ever i saw one. yesterday i thought i would dig this thread up for another look and here it is! my car has started doing this again i'm pretty sure it was after i tried to run the Nav system a few weeks ago. bloody annoying.
Old Dec 4, 2020 | 10:42 AM
MarsE220's Avatar
Merc E220 Diesel estate AMG
My E220 year 2012 radio cuts out....due to Bluetooth connection with Motorola E6 mobile.
Have to turn off radio then turn off Bluetooth on phone turn on radio and then reconnect phone.
Happens every time I make a call!!!!
What a pain....or I could simply not connect the phone.
Old Dec 5, 2020 | 05:03 AM
mondo's Avatar
oddly enough, mine has stopped playing up again. that's twice now.
