E55 Airtek or air lift suspension??
So I recognize that this forum has everyone going for coil overs after the airmatic failure(got a baby leak). Does anyone have a aftermarket REAL AIR suspension not arnott?? and what kit did you use and was it a pain in the neck to install compared to other cars. Im 150% convinced the airmatic suspension is not what i want but I'm making it work with the module and starlink so I'm pretty slammed right now. I also believe that aftermarket air suspension with the coil style are a lot stiffer then our rides (i drive way to fast for this suspension), i think it should prove wonders at high speeds. I do realize you have to cancel out codes with airmatic delete, I'm not worried. This is going to be my first big big mod but my suspension is holding up fine so im just planning.
