E55 AMG Kompressor exhaust mods
Old Jul 31, 2017 | 06:53 AM
Dominik Kuček's Avatar
W211 E55 AMG Kompressor
I want to make car louder,and to have deeper sound...
I am sure someone tested without rear mufflers and similar setups...
What is proved to have best sound?
I am looking for diy,not buying expensive stuff like Eisenmann and similar...
Old Jul 31, 2017 | 09:19 AM
ryanhere's Avatar
05 E55 AMG
You Best , try it in order to
1) C63 AMG mufflers
2) X-pipe in place of Resonator (If you delete Secondary cat you can use it here)
3) Long Tube Headers (Expensive)
Want to Go Louder:
4) Delete the Secondary Cat setup use straight Pipes
Old Jul 31, 2017 | 10:07 AM
SilverDameon55's Avatar
16' GLE63S AMG
Back in the day when I had my C55, I cut the resonator out completely. The cars OEM set up was duals out the motor, to a single pipe/resonator and then back out to duals to the mufflers. I cut the entire center out and made it a true dual set up. Sounded awesome in my opinion
Old Aug 1, 2017 | 09:40 AM
MACEDON's Avatar
05 E55, 98 CLK320
I have all cats deleted and no resonator
At idle the car is still not very loud.
Your options:
-Headers, mid length or long tube (I hear good things about long tubes specifically) (PB5 makes affordable ones a lot of people have bought, MBH is the next step up and recommended if you have the $$$)
-Delete cats and res
-X pipe instead of h pipe
-Borla mufflers (I have read mixed reviews about drone)
-C63 mufflers (best reviewed)
-Aftermarket mufflers (Renntech or Meisterchaft; $$$$$$$$$$)
-Or simply do a muffler delete on your stock muffs, but I heard they will become a bit too loud
Absolute best: MBH long tubes with high flow cats or no cats, with the MBH x pipe, ceramic coated, and meisterschaft mufflers.
