where is my air pump located?
I have a 2007 E63 with some air suspension problems. 3 weeks ago I replaced the front passenger strut. Last Monday I went to work, then a doctor's appointment and stopped by the car wash on the way home. As soon as I pull up to the car port at the house, I hear a loud pop and air coming out of the front driver's side. So I order a new Arnott strut which I will install tomorrow. The car has sat since last Monday. and when I went to move it so it will be in the shade. I see entire drivers side has dropped and when I started the car the air pump did not seem to come on or if it did was not raising the car. So I would like to know the location of the air pump, the air pump relay, and the fuse for the pump just in case it is more than just the front strut.
Last edited by TempeAMG; 09-04-2017 at 12:12 AM. Reason: miss spellings and to have the thread make more sense.
Pump is at front driver's corner. Lines emanate from there to all corners. Sagging is usually because of shock hardware or bags.
Air tank resides in passenger rear area in trunk.
TempeAMG (09-04-2017)
PLATINUM SPONSOR
Nice DYI project on the stray you found! Air shocks look great! Is the engine surface corrosion from salt on the roads? You may be able to pressure wash most of it off, to keep particles from falling in all the parts you may change out.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
