Supercharger belt problem (seriously)
Hey, about a month ago my idler pulley ripped itself off (front part), the back part was still intact but I just ordered the whole thing to call it a day. Long story short, I just put the thing on and I can't get the belt back on. No, I'm not retarded.
I obviously also had to put the other belt back on which I could almost do with one hand after pulling the belt tensioner all the way back / down. It was easy.
Now the SC belt is absolutely impossible to put on, it's just too short. It doesn't matter if I fixate the tensioner with an allen key or keep holding it back with the wrench (which gives you a tiny bit of extra legnth)
SC and Crank pulley are stock and the idler pulley is also the exact same size as the old one. It's also the same belt which was on there before. (1289mm)
First thought would be get a longer belt. I live in Thailand and I have to order all my parts from EU or NA which takes a while to arrive (+ import duty is a bit**)
So i'd really appreciate any help if there's anything else I could try to get the thing back on.
Thanks!
Thanks!
So it can only be two things either your trying to install the belt incorrectly or the part you recieved is not correct. Ensure your putting the belt in using the right pattern. What part number is your new tensioner assembly?
Part # A1132020419.
Regarding putting the belt on incorrectly, I doubt that's the problem since it's really straight forward and appears to be much simpler than the serpentine belt which I put on without any trouble whatsoever.
Just for reference, this is how I put the belt on, red numbers indicating the order.
Crank pulley - SC pulley - Slide under tensioner - TRYING to go on the idler.
It's definitely sitting in all the grooves correctly and the tensioner is released as far as it goes.
I have also tried a different order, putting it over the SC pulley last since it has this smooth edge where it might slip over more easily, but no dice the belt just seems to be too short.
obviously it should fit if you are replacing exact size pulley's .. i put one on several months ago and i had to use a wrench and hold it back as you reference and sort of force on the new belt by getting it almost in place then rotating the the belt assembly with something (i forget what i used) .. very tight as you describe -- actually too tight because the bearing wore out in a couple thousand miles -- get a new belt 1cm longer or get a smaller SC pulley
Guess I'll be ordering a new belt then. At least another 2 weeks of riding taxis, woohoo..
Thanks anyways.
At least this confirms I am not crazy and the thing is indeed either too short or VERY tight. I am almost certain this was also the reason why the idler pulley broke off in the first place, too much pressure from the belt since it was too short I guess.
Thanks anyways.
Thanks anyways.
I have replaced the idler pulley, this thing:
Part # A1132020419.
Part # A1132020419.
