Would these wheels fit an E55?
I have a 2004 E55. I am worried about the brake clearance. Let me know what you guys think.
OEM MERCEDES AMG18' staggard wheels, tires and TPMS Factory takeoffs 2012 Mercedes E550 coupe
Front wheels: 8.0JX18, offset 45mm, tire (235/40/18)
Rear wheels: 8.5JX18, offset 48mm, tire (255/35/18)
As the stock E55 wheels are 18inch these wheels will clear the calipers on the vertical plane of the wheel. The offsets are different from a stock wheel so that may cause interference on the horizontal plane. The wheels may also look odd in the fenders with those offsets. The other factor is they are narrower so with the smaller tires will give less traction which these cars are already short of.
SPONSOR
2007 Mercedes E63 AMG
sorry no...high offset would mean the wheels are sunk in towards the car. a zero offset would mean the hub center line is at the exact center of the rims width.
low riders run something like -30 or -45mm offset wheels with 13 inch to get that outside floating look.
