Go Back  MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG, E43AMG (W210, W211, W212,W213) > W211 AMG
Second Alternator took a dump. Looking for electrical guru troubleshooting advice. >
Old 10-06-2017, 03:42 PM
2005 E55
Hey guys,
My OEM alternator went out about 2 months ago. Voltage randomly dropped one time to about 12V and gave me the warning but came back up after a few seconds, then it didn't happen again for a few days. The it happened again a couple more times randomly, then I saw a spike to about 16V, it dropped to battery voltage and didn't pick back up again. I tried the regulator first, but it ended up being the alternator.
I've had my new one in for about 3 weeks and two days ago I got the stupid voltage drop randomly again to battery voltage. It picked right back up to normal, and ran out basically the same course as the first alternator dropping a few times then coming back, then a spike to 16.5V and toast.
When the alt was working I measured 12.5V front battery, 11.9V rear battery, and both of them picked up to >14V with the car on. I'm guessing there is maybe a faulty component some where over loading the alternator maybe, I was just wondering if any one has seen something similar to this or if has any ideas of the culprit? I don't have the total current draw on the alternator while running but I'll grab it next time I have a working alternator in. Just looking for any trouble shooting ideas.
Thanks guys.
drothgeb is offline
Old 10-06-2017, 04:28 PM
bbirdwell's Avatar
'99 and '05 E55 AMG
PM me your email address and I'll email you some tech info on the dual-battery system if you don't have it already. For now, I'd hook up the diagnostic system and query the Battery Control Module for faults. I lean towards a bad alternator but the exact same failure symptoms sure make one suspicious...
Edit: just re-read your post. 11.9 volts on the rear battery is way too low. Pull the ground cable; if it still reads 11.9, I'd suspect a bad battery. This is why I recommend the Solar BA-5 or 7 battery test device; it allows me to track the health of the battery and replace it when the cranking amps get too low.
bbirdwell is offline
drothgeb (10-06-2017)
Old 10-06-2017, 04:34 PM
2005 E55
Awesome thanks for the info, I found several threads where people were suggesting that upper 11s were okay on these batteries. I'll get that turd swapped out along with the alternator then.
drothgeb is offline
Old 10-06-2017, 06:56 PM
rapidoxidation's Avatar
2005 E320 CDI
How old is your main battery? 11.9 is well below the 12.3V minimum that a battery should show at rest. Get a load test on that battery; I'll bet you'll find it is the reason your alternators are being killed.
rapidoxidation is offline
GatorMB (10-07-2017)
Quick Reply: Second Alternator took a dump. Looking for electrical guru troubleshooting advice.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
