Quick airmatic relay question
do I have the wrong replacement?
The answer is "It depends upon the application". A 5-pin relay has a Normally-Closed in addition to a Normally-Open connection. The Normally-Open connections are always on pin 87. So, techically it is the wrong relay but it might work; depends upon if the circuit needs to "see" a normally-closed connection.
Power and ground for the solenoid in the relay come from pins 16 and 39 of the Airmatic module. I don't know which is power and which is the open-collector ground.
Hope this helps.
