Hard breaking
I like SBC but it is a single chain and not redundant. Be prepared.
FWIW, it was over 120 pages I emailed to our newest addition to the sub-forum..
Isn't there a counter to let you know when to change it out?
W211 SBC count check or reset
Start engine. (Note: Engine does not need to be running to only obtain count.)
Start xentry, go through menus for your vehicle and go to:
Control units
Chassis
SBC sensotronic brake control
development data
Actuations (should be at the bottom of the menu so scroll if necessary)
Complete index of Actuations
Break: To only get the count, select “Bremsenzaehler (DF_GetBrLiveTime)”. This returns the total count to date.
Stop here if only getting the count and back out of the menu using the F1 key. Continue if you wish to reset.
Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen
set ulNBR to 0, click F3
Bremsenzahler auf beliebigen Wert setzen
Lebensdauerzahler F neu berechenen und schreiben
log out of xentry
Do not turn off car.
Drive or let idle for at least 10 minutes. (NOTE: 10 minutes is minimum time required due to the data collection parameters in the distributed digital control system.)
