E55 amg battery drain
Ok another update looks like previous owner installed this emulator and now thinks that someones sitting there the whole time.... so wtf? Why do i have a battery drain from this?
'99 and '05 E55 AMG
F85 should be third from the left in the rear pre-fuse block.
The seat occupancy emulator may be because the OEM sensor is broken a previous owner did not want to pay to repair it.
Thanks birdwell i saw some info on that and i ordered some fiber optic loops to bypass telecomunications and voice control, as of the seat issue im gonna see if i have any drain with the seat belt on the passenger seat and with fuse n35 on 🤔🤔
Ok so im not sure why i still have that drain it is from fuse n35 weight sensoring system
but im not sure what else to try i took the seat off put it back on it has the bypass emulator on the weight sensor, but not the bypass for the sear belt, anyways i tried leaving the sear belt on but i still have that 1.70 amp drain coming from there, anyone have any ideas? I did wait +30min to make sure everythings asleep...
If i remove fuse 35 for weight sensoring system it goes down to 0.02 so no drain which is where i want to be, but what could it be causing this issue if its not the passenger weight sensor
that has been bypassed...
'99 and '05 E55 AMG
Is there any way to unplug the weight sensor? If that doesn't do it, some way to follow the wires back to the module that is connected to the weight sensor? I'll look again at the schematics; I can only see a small portion at a time and gave up trying to find the weight sensor circuit. I"ll try again but it could be a day before I have time to do so.
Ok
so yeah this stupid emulator bypass is whats drawing the battery, if i wait a lil more it gets closer to 0.01 so i put the oem back
but as expected i get the srs malfunction so i guess i have 2 options
try another simulator or actually fix the problem does anyone know how costly it is to actually fix this crap? To see if its even worth it, if not ill try another emulator, idk let me know if anyone has any suggestions and thx birdwell for ur help 👌👍
#32
'99 and '05 E55 AMG
http://www.benzworld.org/forums/audi...placement.html
Go to the third post.
You'll need to confirm the part number for your car. Doesn't look too difficult nor too time-consuming.
#33
Great, thanks i actually ordered another bypass emulator thing to try, if i get the same results ill fix it the right way!
hope this helps anyone if they go thru something like this lol
#34
'99 and '05 E55 AMG
Here's the DIY using a W210 seat:
http://www.benzworld.org/forums/w210...placement.html
