Clutch Delete Supercharger Pulley! No more Heavy Back plates!
Old Mar 14, 2018 | 08:40 PM
Davednconfused's Avatar
2005 E55 AMG
Originally Posted by VictoryRoadPerformance
Our test car did put his car on the dyno before and after although he went from a 76 clutched to 74 CD , he will be hitting the track shortly (we just sent him the new textured pulley to test out)
We have these available in every size from 90mm - 70mm. So More data coming in soon!
Edit:
Before: 534 On Dynojet
77mm clutch
Midlength Headers
82mm Tb
No cats or reso
K&n filters
Bwk
FTP HX
630cc injectors
EC tune
Colder plugs
3” intake
3” exhaust
After: 573 Dynocom
74mm clutch delete
Midlength Headers
82mm Tb
No cats or reso
K&n filters
Bwk
VRP HX
630cc injectors
EC tune
Colder plugs
3” intake
3” exhaust
Of course these dynos were taken some time apart, and heat exchangers were changed so take them as you will. We are getting more Dynos as time goes on, but best to have before and afters.
Not really sure how these numbers are relevant... different dynes, different days, and even different pulley sizes.
My thought is that shedding the rotational mass isn't worth rendering your SC unusable for any pulley besides this one. Back to back dyne pulls will tell all though.
Old Mar 14, 2018 | 09:01 PM
Style_Front's Avatar
ez-go
Originally Posted by tw2
Maybe they did and couldn't prove a difference. Removing rotational mass is never a bad thing but whether there is a significant measurable improvement is another thing entirely.
Perhaps.
It would take tight controls in order to demonstrate. With heat management being what it is on our cars the same car with ZERO change can fluctuate power figures + or - enough that the benefit of the weight reduction gets lost in the shuffle.
But, what I'm reading is no attempt was made.
With the momentum of inertia it depends on 2 things, the weight and diameter. This pulley shrinks the outer diameter and reduces weight so 2 victories to be had there.
I just think they should have made the effort to demonstrate that.
After the results come in then we can accurately make cost/benefit choices as the consumer.
Old Mar 15, 2018 | 12:19 AM
tw2's Avatar
tw2
I am not convinced a dyno will show anything as I don't think the amount of power required to maintain that increased angular momentum is great enough. I think you will looking at margin of error. You would expect the engine to increase rpm faster with less rotational mass to drive, may be 0-100mph times would be more appropriate? I am not a physicist.
Old Mar 15, 2018 | 05:20 AM
ez-go
Removing rotational mass on the engine is felt most in lower gears. Like everything else that spins, the transmissions gears multiply or divide those forces. Well, at least it does so for everythingethat spins in front of the transmission. Everything after the transmission output shaft yields constant results. So, you may be right. Since most dynos use 4th, or which ever gear provides a 1:1 ratio, not all of the benefit may be captured. While the Dyno may capture a small benfit in 4th the ease of angular momentum would be even greater through the previous gears.
Old Mar 15, 2018 | 11:25 AM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
We still have numbers coming in, the most difficult thing is to find a vehicle with a 76mm clutched, that wants to go to a 76CD and not 74, or a stock car that wants to stay 90mm, we have one more test car lined up with a 74 fixed, who will be swapping out for 74 CD.
Well thats why I very clearly stated the specifics of the 2 runs, Many fixed pulley customers have no intention of going back to clutched, Changing to a CD is a pure upgrade from a standard Fixed pulley.
Old Mar 15, 2018 | 11:43 AM
new55's Avatar
04 55
Cool
[QUOTE=VictoryRoadPerformance;7405130]We still have numbers coming in, the most difficult thing is to find a vehicle with a 76mm clutched, that wants to go to a 76CD and not 74, or a stock car that wants to stay 90mm, we have one more test car lined up with a 74 fixed, who will be swapping out for 74 CD.
how about 83mm numbers numbers -- lots of folks running clutched 83's , maybe they will go for CD option - i like the concept and agree with the poster who mentioned the advantage will be in the rpm from idle to wot - not a 4th gear dyno pull,, these cars are getting so old and devalued right now i dont think its going to matter that much if they are 100% stock or not as long as they are not beat to crap -- keep us posted please
90% of the fun for 10% of the cost of a new amg
Old May 22, 2019 | 11:20 AM
  #32
ctravis595's Avatar
2002 CL500 to CL55 conversion
im thinking of installing a used kompressor on my n/a 5.5 instead of a turbo... since the kompressors can be found so cheap these days. this fixed pulley might answer a lot of my problems in regards to programming/needing a m113k ecu for this swap. however i think ill need something more like a 100mm pulley because i want to run low boost on my n/a 55?
Old Jun 19, 2019 | 02:35 PM
  #33
SPONSOR
E55 C63
Photos from some of our great customers
Old Jul 7, 2019 | 11:02 PM
  #34
anton28's Avatar
2023 Rover
Any dyno results?
Old Jul 9, 2019 | 03:29 PM
  #35
SPONSOR
E55 C63
Old Nov 21, 2019 | 11:50 PM
  #36
SPONSOR
E55 C63
on sale right now!
Old Nov 22, 2019 | 06:09 AM
  #37
new55's Avatar
04 55
numbers ?
Old Nov 22, 2019 | 09:57 AM
  #38
SPONSOR
E55 C63
Originally Posted by new55
numbers ?
There are numbers posted in this thread above.
here is a customer running a 74 clutch delete with 188 modular crank, 102TB, Longtubes, Ported Blower, Stock heads, stock cams, Stock bottom end. (Find me another Stock Motor 55 making 658whp)
Another customer Just ran 10.6 With 180 Lower and 90mm Clutch delete upper
The testimonials are all over the facebook groups. The clutch deletes work, and companies are now copying the design.
This is a testimonial from Travis Howard I have been going back and forth about posting this because he tragically passed away in his sleep before we had a chance to publish this information. He was the person We mentioned earlier in this thread that was testing for us. Im more than happy to show screenshots if anyone has any doubts. But this is what he said after going froma 72mm Fixed to a 72mm Clutch Delete
11/29/18, 7:26 PM
"Had to correct the temps to what my last dyno run was at 555whp. Made 579whp. Running 3 more degrees of timing. And your pulley.
Car gained alot more power and torgue on the low end and mid-range, but not much up top. However, the pulley works
Thinking of a 68 shark bite now"
he ran 11.2 with the 72mm Sharkbite and following mods:
Sealevel and FULL bolt on
Longtubes, straight pipe, cls63 mufflers, 82mm tb, meth, e85, etc
Florida
It's 66f ambient
From 11.5 with 72 fixed to 11.2 with 72 sharkbite
Old Nov 23, 2019 | 10:26 PM
  #39
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
Is it possible to leave the magnet on with this pulley? Not being able to return everything to stock puts me on the fence.
Old Nov 25, 2019 | 11:19 PM
  #40
Rpkxnoscope's Avatar
CLS55 AMG 06
This is soo awesome and such massive gains, I actually can't believe people think removing the clutch and magnet is a placebo or some other dumb ****. I just want to fix my damn ticking cls55 having a ****ed oil pump so I can mod the SC and do other fun things instead of hearing this gay *** ticking, soon, soon..
Old Nov 26, 2019 | 11:22 AM
  #41
SPONSOR
E55 C63
If you are on the fence try a fixed pulley for a little while... If you like the fixed youll love the clutch delete.
Old Nov 29, 2019 | 09:30 AM
  #42
SPONSOR
E55 C63
Black Friday pricing on these!
Old Dec 18, 2019 | 06:12 PM
  #43
fkong777's Avatar
Are the fixed pulley back in stock? Also Is there instruction on how to remove the magnet?
Old Feb 27, 2020 | 11:08 PM
  #44
BC928's Avatar
2006 E55, Various other German and ‘Murican
An additional important piece of the puzzle here is that with fixed pulley, we have some supercharger clatter. Some noise.
Now without the 8 pound barbell spinning around with the rotors - does this make that issue LESS or MORE prevalent.
Newer superchargers don’t clatter because they have some sort of isolator. But if we lose this weight - what does it sound like?
Old Feb 28, 2020 | 01:54 PM
  #45
builtbyfood's Avatar
2004 E55
The chatter is from the rear bearings going bad, not from the removal of the pulley. I have been running the pulley for over 2 years now. One of the first to do it with VRP. I have done the delete to a 280 and 580 blower both performed great.
Fun fun fun
Old Feb 28, 2020 | 02:09 PM
  #46
BC928's Avatar
https://www.youtube.com/watch?v=ELqnu-ZLtIY
https://www.youtube.com/watch?v=W9NuIkofwVc
Fun fun fun
I was saying any non clutched or fixed setup is said to cause chatter - but that’s good anecdotal evidence, and I just changed the bearings last night. I have to order some stuff from them anyway. I’ll speak to them.
Old Apr 17, 2020 | 07:51 PM
  #47
eurochargedw210's Avatar
w210 E55
E55
I know the highest horse power stock blower E55 in the world runs a clutched pulley, and the fastest E55 in the world runs a clutched pulley also.
Old Apr 18, 2020 | 10:37 AM
  #48
SICAMG's Avatar
2005 e55 AMG
The chatter is the slop in the gears. You can make the noise just by turning it by hand. Second if you had the same size pulley clutch or no clutch I can bet that the power would be the same. Yes less weight with none clutch but you are not creating all this hidden power. Just my 2-cents.
Old Apr 18, 2020 | 11:27 AM
  #49
2004 E55
The only thing you unlock is the ecu taking away boost.... hehehe
Old Apr 18, 2020 | 11:43 AM
  #50
SPONSOR
E55 C63
Yeah, There should be some pretty big shakeups this year in the fastest 55ks, There are people building some pretty ridiculous machines right now. We all know how great the stock supercharger is, just because the fastest car right now is running clutched really doesnt mean anything at all..
here are the facts, Fixed/CD setups are instant boost and they are lighter. I would be willing to bet if the "fastest car" switched to a clutch delete, it would STILL BE THE FASTEST CAR. I bet you if the highest horsepower E55 in the world switched to a clutch delete pulley it would STILL BE THE HIGHEST HORSEPOWER.
Its not, its the same boost, but removing the rotating mass is effectively adding a lighter crank pulley or flywheel, it also reduces belt slip. When you put the clutch delete on, sit in the car and rev the engine the RPMs raise faster, and drop faster. There is a definite and noticeable difference.
Given that for probably the last 6 months the Clutch delete pulley has been our #1 selling 55k product we are probably up to 250+ sold, People are extremely happy with it.
