E55 gearbox issues
E55 gearbox issues
Hello guys i have a w211 e55 amg after parked for a while the gearbox shifting from 2 to 3 has a delay about for 3 seconds+ an revvs up before engaging... any advice will be appreciated . Thanks 😆
Yep if you want to correct the issue you first have to diagnose the problem, to do that with your transmission you will need a good transmission shop that understands the MB transmission. The alternative is to take the Bens Wurld finger in the wind approach and start throwing parts at the car----change fluid and filter bla bla bla
Received 1,008 Likes
'99 and '05 E55 AMG
This is what you will see when you scan the transmissio:
https://mbworld.org/forums/w211-amg/...rmination.html
