front rotor for mercedes s55 amg 2005
hii all i have a mercedes s55 amg fully weistec built the car is 680 hp i need a good front rotor to my car hf anyone can help me
Try RockAuto they should have the rotors that you seek. If not then try AutohausAZ.
The enemy of any braking system is heat, and this especially true on the S55. Now the S55 came with big beefy 8 piston front calipers with solid crossed/vented front rotors.
One would think that these brakes are more than sufficient. But as you brake the weight shifts from the rear to the front, and typically the front brakes apply 70% of the total braking force.
So installing two-piece rotors may solve the situation, as the heat is retained in the friction rings, and not transferred into the hat. So theoretically you should have better braking performance, with less fade.
Retaining heat (in the ring) does not lessen brake fade which is due to pads operating outside their specified design temperature. 2 piece rotors reduce weight and stop you cooking your wheel bearings. To reduce fade you need more thermal mass, better dissipation or a material that won't fade when very hot like carbon fibre which just accelerates wear rather than reduce braking performance.
Im working on this problem too...i was gonna try put an air intake at the front bumper and run a duct back to the rotor, cut and weld a metal intake to the metal rotor shield cover thing to try apply air to the rear ams create a sprinkler affect..
How is that? - I mean that in a sincere way. The two piece probably have better airflow through the inside of the rotor but otherwise I'm not sure how they would make a significant difference without altering the factors I mentioned above.
The original post stated that he needed a good front rotors, and the two piece is better than one. Is has better thermal dynamics then the one piece, less weight, and dissipates heat better. What else do you want me to say.
Again only for the sake of discussion I believe you either need a large rotor mass, better cooling design or higher temperature rated pads to counter fade. If the fluid is boiling then higher temperature rated fluid also. If there is a 390mm setup available that could help. I will leave it be. And you are correct, the OP has not stated the actual brake performance issues they are facing.
I have 280mm P030 two piece front brakes. With EBC redstuff pads they would overheat in cruise control from the computer programming. Even without cruise I think they drag often enough to stay hot and dry. Stock pads stopped the overheating problem, but I can see it in the gas mileage that they are still active without cruise. There is more to these brakes than physics. When they tested a new CLS (2006) on top gear they overheated the brakes from the traction control, with it turned off!
