P030 package air bags?
Is there somewhere else other than the stealership I can get the rear air bags for a P030 package E63? I don't want to use the Arnott's as you lose the ADS function. Everything I have found says "without performance package".
arnottdoug (08-23-2018)
Former Vendor of MBWorld
Arnott Rear Air Spring for W211 W219 AMG
Arnott's A-2725 Rear Air Spring for the 03-09 E-Class W211 and 05-11 CLS-Class W219 AMG (with AIRMATIC & ADS) will work perfectly. These install up to 90% faster than the OE because you don't have to drop the sub frame like they must at the dealership.
https://www.arnottindustries.com/a-2725-arnott-rear-air-spring-03-09-mercedes-benz-e-class-amg-e55-e63-05-11-cls-class-amg-cls55-cls63-left-or-right
another question to Arnott...the site says "eliminates the OE reservoir". Question: Whats the purpose of the OE reservoir, that its ok to no longer have it?
Sport 1 and sport 2 close valves to reduce the volume of air that compresses when you hit a bump. Comfort mode extends the air volume all the way out to a separate reservoir. The smaller the air volume, the more the pressure increases as the air spring gets compressed. I think there is also a fluid control valve in the shock that makes them too complicated for aftermarket companies to build.
