Talk about pulley failure
A different spin on it but a hairline crack unnoticed then this
eFifty5AMG (10-30-2018)
It’s the same pulley that’s on the tensioner but I use it on a belt wrap kit ,it is not on some type of set up with manual tension just an idler pulley ,yeah freak thing
Yikes! Mine seems to have slight lateral play (and has worn a good bit of green color off my new belt), wanted to see if I could replace the bearing. Does it look like it would press out? And does yours have play as well? Might be too destroyed to tell...
that’s the part number ,for that tensioner pulley , they don’t sell it separate under E55 part numbers
How fast was you going when the failure happened? It probably scared the s**t out of you.
Its a wonder that you didn't tear up more stuff, like your radiator, cooling fan, hood.
yeah took out the hood
