Need help with electrical question on battery relocation on SL... Safety related
I'm going to be removing the factory installed positive battery cable and will be running a new one. I found the power distribution block in the front of the car. It's located on the firewall about 1' down on the left side of the engine bay. Inside of the car, it's located in the passenger side footwell area underneath of the carpet and Bose subwoofer.
With the cover removed on the inside, you can see a 250 amp fuse and 100 amp fuse. The 100 amp fuse is for the starter battery in the front and the 250 amp I believe is for the larger auxiliary battery in the rear. (please correct me if I'm wrong)
Instead of running a new cable from inside of the engine bay and through the firewall, it's seems logical to just start the new cable at the source which would be the distribution block in the passenger footwell area inside of the car.
I'm basically trying to avoid having to attach a new cable where the factory cable was removed from which is in the engine bay. This way I don't have to route the new cable through the firewall and all of the cable would be inside the car.
Can I just attach a new cable/lug to my wire and put it on the top post as indicated in the picture? It would be stacked on top of the lug with the red wire that's already on the post which gets routed into a box on the floor. Not sure what this red cable is for? Will I still be utilizing the factory 100 amp fuse in the block and receive charge from the alternator by attaching to this top post that's inside of the car?
What's wrong with trying to learn new things and ask for help when needed? I've been wrenching on my own cars for the last fifteen years and have become very knowledgeable on most things automotive from DIY maintenance and projects.
Are you the type of person to get everyone else to do everything for you because you're afraid of learning/trying new things?
