Originally Posted by SICAMG
(Post 7970451)
Hey I ported mine as well ! Smoothed out all the transitions like you said and removed any casting flash. Make sure you turn the gears as you snug up the pump. The housing can bias the gears a little when not perfectly centered. At first I just tightened the bolts and noticed a very slight bind, then loosened them and snugged them up while rotating the main gear.
(Post 7618415)
The regular 0w-40. When I race I use the 5w-40 which is a little more noisy.
LEICHTLAUF ENERGY 0W-40 Cant find this available in the UKSYNTHOIL ENERGY 0W-40 this one is readily available but only covers the MB229.3 spec but not the MB229.5.ive been experimenting with different oils since i bought the car 2 years ago, |
None of those oils.
Looks like the oil pump scavenging gear noise is being addressed with lobe type gears.
Originally Posted by mbmg
(Post 8210619)
Looks like the oil pump scavenging gear noise is being addressed with lobe type gears. YouTube link.
I actually just did most of the job to swap out the o-ring out today. Couldn't quite finish up to see if it had any effect on the more pronounced noise mine has been making lately, but the O-ring was definitely hard and brittle. It makes a clank noise when you drop it on a metal table for instance. The difference in seal quality between old and new o-rings was night and day as well. With the old one, the pipe just falls right out. There was virtually nothing holding the two pieces together, not even suction. With the new O-ring, it's actually quite difficult to even put the pipe into the hole and once in it stays in place, the seal is that tight. Seeing it in person makes me realize how poor the design really is as well. There is nothing really holding tension on that joint. The O-ring is only being pressured in the radial dimension by the smaller pipe it fits over, and the larger bore it fits into. There is nothing to apply force inward and crush the washer between the raised section of the pipe and the body of the pump, which would help maintain a seal even if the rubber hardened in my opinion. It's just held into position by the brackets that attach the pipe to the bottom of the engine block, and they are not positioned precisely enough to apply the proper forces on this joint. This can be clearly seen in the shape of the old washer, which was squared off on the inner and outer edges of the circle where it was squeezed in the bore, but budged out round to the sides because the pipe is not held in the socket with any tension at all. If it was under pressure from all sides, it would be squared off on all 4 sides rather than just 2. I will be finishing up on mine on Friday as the shop is closed tomorrow. Will report back if I got any results. I do know I fixed a bad engine mount in the process though. Unfortunately it splooged all over my workbench when I set it down on it's side and it leaked all of the fluid onto my tools. :( |
(Post 8210619)
(Post 8210265)
None of those oils.
Thanks |
Originally Posted by feeshta
(Post 8210832)
I will be finishing up on mine on Friday as the shop is closed tomorrow. Will report back if I got any results. I do know I fixed a bad engine mount in the process though. Unfortunately it splooged all over my workbench when I set it down on it's side and it leaked all of the fluid onto my tools. :( what oils have you tried and which oil have you filled it with after the new O ring? regards |
I like that guy. I do. Great help in many ways for us that actually take these things apart.
that said.... Im gonna just think Mercedes had a reason to make the pump work the way it does, and changing the gears to reduce noise (and increase flow) doesn’t make sense in 99.8% of the cases. |
That first start whine adds character to the M113K AMG engine. Like a jet fighter firing up, getting ready to go into battle. :) Don't confuse warm engine whine with the power steering pump, especially with slightly raised RPM. I'm going to change the PS fluid, to see if it helps, but will probably require replacement, in 10K miles , or so.
Originally Posted by Lee Phillips
(Post 8214232)
How did you get on, noticed any change in noise? From the XF video it would seem the noise indeed mostly comes from the scavenging section, so would be surprised if changing the O ring effects the noise but should definitely increase flow and oil pressure. ( may have been a good idea to have checked your oil pressure before and after changing it, using the port on the front of the oil filter housing.)
what oils have you tried and which oil have you filled it with after the new O ring? regards Lee Bottom line is that it did drastically reduce the noise, but didn't quite eliminate it. It was inaudible inside the car for the first few days after the repair, but came back a bit today, which appears to be related to cold weather we are having here. Even today it is not nearly as loud as before, but enough to be slightly irritating to someone with a sensitivity to noises like myself. Right now it is probably third on my list of hates about the car to a squeak in my dashboard and another one from the passenger headrest. LOL! I absolutely hate it when cars make sounds that they shouldn't. I've been known to spend dozens of hours tearing things apart and installing sound deadening materials just to stop 1 squeak, and at the moment I am seriously contemplating tearing the entire dash out of my car to find that damned squeak, as well as removing the passenger headrest. If there is one thing squeaking on the interior, it's basically all I can hear. It might as well be someone chewing mac and cheese with their mouth open right next to my ear. I have a problem, I know. You can find the rest of the details in the other thread, and there is some video of the noise before and after for comparison. |
ok, thanks I will move over to the other thread, funny thing is im always googling this issue but never find any threads besides this one LOL
