WHICH LSD is Better for E55?
I'm thinking about LSD, is it worth the cost and why? Wavetrack or Quaifi? Are there other alternative on LSD brand? Should I invest on other mods instead?
Below are my mods...your input is appreciated.
2006 E55 AMG: VRP 76mm S/C pulley, VRP BWK, VRP heat exchanger, VRP Split cooling kit, VRP Superflo, MB (VRP) 82mm TB, Bosch (VRP) 550cc injectors, Upgraded Super Cheap Stolen Chinese LTH, NGK colder plugs, RaceIQ tuned ECU.
Quaife for better DD and wavetrac for morr agressive diff imo. I have the wavetrac its a bit rough at low speed tight corners but great on track and grip is great even on rough roads (big bonus for me).
Posted these in w219 but will do them here for w211.. took dealer 10hrs to drop out the diff houding and to put it back. I took housing to a diff specialist to have it swapped (2hrs at specialist ay 80nz ph).
Parts needed below.
48.309.185WK Wavetrac LSD qty1
2309970346 Mercedes Benz Seal Ring - Interior Flange qty2
2203570790 Mercedes Benz Protective Ring qty2
003531373 Mercedes Benz axle nut qty1
2303500349 Mercedes Benz rear left carrier bearing qty1
2303500249 Mercedes Benz rear right carrier bearing qty1
Parts needed below.
MSG 55G (12-21-2018)
Thanks, I thought about 10 hours but it's good to know what other dealers are quoting. I was thinking wavetrac but I am only street driving. Maybe quaife would be better, at least there is a dealer here, NZ$2100 I recall.
Yeah i dunno what roads like in hamilton but here in chch they **** so i wanted the diff to stay locked over bumps. Im gonna switch my wheels over tomorrow ill let you know if its smoother at park lot/intersection taking off into right turn speeds. Basically i think it goes to or near 100% lock so very very slight hop judder feel from rear in that situation only. I dunno if it a wavetrac or justcgeneral aggressive after market thing.
The wavetrac is amazing in corners and in straight line my god it better so much tighter. Rear end was like a whales tail before fooking esp diff side to side wollow.
I have read many comparisons from all different forums. I think for a street car you can't go wrong with either. I think I will just get which ever is cheapest with a bias towards quaife since we actually have an official distributor here.
Thanks guys for all your comments, still on the fence on LSD. Most likely going with Wavetrack cause VRP have it on sale this month; however, not sure if I need it. I don't plan on tracking it (don't think there's a 1/4 track in So Cal), what are other benefits to get LSD other then better grip? When installing LSD, would you truly see a difference from the get go?
The rear end tightens rignt up. Pre lsd my rear end would sway side to side when smashing it in a striaght line even with esp off because the brakes keep getting applied to one wheel then the other to try sort the open diff. There is also a hesitation in 1st to 2nd gearshift under wot that is from the esp cutting power because the transmission does not want to shift while the wheel speed sensors at the rear have exceeded the tolerance for spinning at a different speed.
honestly of all my mods it made the biggest difference in my mind.
HubTraum (03-20-2024)
But it will be worth it!!
Most likely gonna go with Wavetrack from VRP, Phil recommended to me plus he has them on sale for $975; AND!!! he owes me my core refund on my snout. Not sure how y’all feel about VRP, but Phil done-me good with many wised advices and supports when I started modifying my car; i.g. No CEL when I installed 82 TB or any other mods on advisements from Phil at VRP and Tony from RaceIQ promptly sends me two re-tunes (no charge) in a matter of a few days when I told him about my pending additions.
I forgot to ask. Did the dealer suggest taking it to the differential specialist? I thought they would have been able to take care of it without much trouble?
Nah i suggested it originally coz i knew diff specialist was 80 or 90 ph and quoted 2 to 4 hours, think it was 300 including diff oil in end. I suspect if i had gone to dealer theyd have just sent it to them anyway, i know they use other companies for alignment and muffler/welding work and some other **** like repairing my axle. But if they use those companies on your behalf they charge markup.. They didnt offer to do it all themselves so im pretty confident.
Disclaimer i love the lsd coz im mad dog and smash my car on the daily so really notice it the open diff and esp system is probably plenty for more casual everyday folk or stock cars, i got decent mods so maybe it important den.
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
