87geeinn |
05-30-2019 02:36 PM |
How many miles on the vehicle and when is the last time the spark plugs have been changed? Sounds like a failing ignition module(s). Very simple to diagnose and having owned an '07 E63 that developed a misfire, I can tell you it will not throw a code. Download the TorquePro app (last I checked, it was like $5) and get a matching ELM bluetooth dongle (about $12 on Amazon). Drive the car around for a bit and then connect it to the app and run the "Test Results" section. It will tell you overall misfire events and misfire events for each drive cycle, for each individual cylinder. You will know if one is going bad because the numbers will be much higher than the other cylinders. Individual coils are ~$45 on Amazon. Undo the electrical connector, remove two screws and just pull it straight out. May have to twist it from side to side to loosen it up from its grip on the spark plug. Installation is the reverse of removal. Easy peasy. You may have more than one going bad so again, compare the misfire events for each cylinder.
I made a post about it with screenshots explaining this so if you can find it by searching my posts, that will help. I tried to locate the post but am getting an error on the site ATM.
