285/30 19 x 10 +35 Rears?
Rather than try and recycle an old thread where the info is close to what I'm looking for (I didn't want you guys to think I hadn't at least searched lol)...I'll ask the specific question:
Ok, so to be clear, please...285's on a 10" rim will not rub in the back (on stock STAR lowered suspension)?
I ordered some Forgestars 19 x 8.5 +28 F and 19 x 10 +35 R
The wheel company recommended a 245/35 F and 275/35 R tire combo...but that will result in the rear tire having a slightly larger overall diameter...(25.8 F and 26.6 R)
If I go to a 275/30 in the Rear I would have a smaller overall diameter in the rear than the front which to me is just wrong...
so I ordered Michelin PSS 245/35 F and 285/30 R which have identical overall diameter of 25.8" (which is also only 0.1" larger diameter than stock)
TireRack also called me to verify the size since it's not what they recommend....
I just want to be sure they won't rub before I confirm the order.Is anyone running this option without issue or fender rolling?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
I know that I could fit a 285 on my 07 E63, without any issues.
boosted305 (05-30-2019)
Thank you sir...what offset are your wheels?
My rears are a 35 offset and the front are 32 offset
19x8.5 F and 19x9.5 R so a 10” rears wouldn’t be an issue for a 285.
boosted305 (05-31-2019)
Offsets?
Keep in mind that my wheels are concaved in design. And the rears have a slightly negative offset meaning the mounting flange is towards the middle and right of the center line of the wheel. These BBS wheels looks like they have a positive offset.
