W211 E55 P0130 Code
Old Jun 27, 2019 | 11:12 PM
JaviersE55's Avatar
2004 E55 and 2018 Challenger SRT scatpack
W211 E55 P0130 Code
Hello everyone, I have a P0130 Code along with a Cyl. 3 and 4 misfire. 'Anyone know where I can start to fix this. I was reading that it could be a bad Injector/s. Also researched
that a bad Bank 1 oxygen sensor could be the culprit. Any input would be greatly appreciated.
Old Jun 28, 2019 | 12:37 AM
Rascal203's Avatar
05 E55 AMG , 07 ///M Coupe
I would honestly start by swapping out those coils and plugs to another Cylinder, clear the codes and the run the motor to see if they come up again and if they have now moved over to the new cyl you put them on and then you can identify if its the plugs or coils before testing injectors and O2 sensors...In my experience, 8/10 times, misfire is related to bad plugs or coil packs.
