Accidentally touched both positive and negative on battery
Old Nov 2, 2019 | 01:53 AM
ta72's Avatar
2006 CLS55
Hi,
I was working on the battery area and accidentally dropped the ratchet onto the battery. The ratchet touched positive and ground causing a slight spark for about a couple seconds. My car started normally after that. My questions is, is there some kind of circuit protection on the Cls and E55?
I would think it might of slightly fried the ecu or fuse, but the car started it fine. Does it have some sort of protection from this? if so, could it be the battery voltage module? Or something else? What and where should i check? Im hoping i didnt fry/damage anthing.
Old Nov 2, 2019 | 05:49 AM
coobah's Avatar
'04 E55 Wagon
Well... If everything works I would be happy that I was so lucky 🎃
Old Nov 2, 2019 | 07:08 AM
SICAMG's Avatar
2005 e55 AMG
Your fine, you jumped it at the battery so the battery is what sparked. Nothing to do with the car it self sparking voltage wise....just the battery.
Old Nov 2, 2019 | 01:48 PM
ta72's Avatar
2006 CLS55
So if i touched positive and ground from other areas of the wiring then i would of damaged something? So battery area is ok? If damage was present, i would of gotten an error?
Old Nov 2, 2019 | 05:16 PM
JohnLane's Avatar
222 S-65
Deep breaths OP. It runs and everything works. You dodged the bullet.
Be more careful.
Old Nov 3, 2019 | 06:34 AM
SICAMG's Avatar
2005 e55 AMG
Going from a positive line to ground some where would more than likely pop a fuse.
Old Nov 3, 2019 | 06:59 AM
hyperion667's Avatar
2012 CLS63
As long as this didn't happen!
Old Nov 3, 2019 | 08:04 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
https://www.youtube.com/watch?v=G5LM8xSuKD4
Classic!!!!
Old Nov 6, 2019 | 11:25 AM
lseguy's Avatar
2005 c230
i hope to be so cool one day as to be able to blow something up and do the cool movie move where you calmly walk away and dont even look back or even flinch.
