Anyone Know How to Get Bluetooth Audio in W211 E55?
This is an example of the many different Bluetooth adapters you can select from.
wiring: $100
enfig kit: $130
deck: $300
amps: $350
sub/box: $350
Attachment 439375
Attachment 439374
this is the only way i would recommend doing it. the lapower thread is full of people having nothing but issues, same with the android heat unit threads. most of the cheap bluetooth adapters are crap IMO.
do it once, do it right
Here you could buy some different options. I like the unit which replaces the cd changer. You keep stock system and get full Bluetooth with steering wheel controls.
Its plug and play and connects to my phone and starts playing music immediately when I start the car.
Some of the modules can be buggy. I had to get my first one replaced and my current once still acts a little funny when it comes to the phone integration. Overall, I am very happy.
Side note, anybody try one of those decks with CarPlay?
https://www.ebay.com/itm/203948646765
https://www.audiotec-fischer.de/en/h...-eight-dsp-mk2
but as mentioned previously...using a bluetooth aux dongle is the easiest cheapest option if planning to keep the factory system. going with any aftermarket unit will replace the seamless and high quality audio ability with phone calls. any aftermarket solution records all background noise as well as voice.
I enjoy the wireless CarPlay and used the I Heart Radio app for local stations bc none of these units work worth crap with the loaded FM tuner. Just stay in Android Auto or CarPlay mode. Mine connects just fine and auto play the I Heart app by the time I had reversed and was ready to drive.
Was super easy to program the steering wheel controls too!! I like could set the touch buttons to any color I wanted so I set to orange/amber to match the stock interior so it blended in better. Most never knew it wasn’t stock
I have a unit I plan to use in my E once it’s back to me.
pic of G install and links to the one I got for my E. I did use gloss black vinyl to cover the plan plastic edges and it made it blend in better. I plan to do the same for my E to closely blend with my real carbon interior. The AMG screen I had on the stock Android side was nice but rarely visible since I used CarPlay but nice if you want to use it and Torque app to monitor things.
E unit is likely this one but didn’t have the lower section bc I have a carbon piece there. But since i had a LED light idiots drilled into my carbon for my meth injection perhaps I should have gotten this style to combat having it there or a hole there if removed. I could black vinyl it all and blend in maybe a little more. Hmmm.
Checked vendors on AE and mine is no longer active it seems. I paid $500 but this below is cheaper.
US $145.05 27% Off | Android 11 6+128GB For Mercedes Benz W211 E300 2002 - 2010 IPS HD Screen Radio Car Multimedia Player GPS Navigation Audio Video
https://a.aliexpress.com/_mqSNAcO
Im still contemplating such an upgrade, but the sound quality needs to be the same (I have the Harman Kardon Logic 7 system in my CLS55).
Unit like the G wagon on and style wise like the one for the E but E has larger/wider screen.
US $133.27 46% Off | IPS 1280*720P Screen Android 11 8G+128G Car DVD GPS Radio CarPlay For Mercedes Benz CLS Class W211 W463 C219 2003-2010
https://a.aliexpress.com/_m04daEi
E version is most like this but isn’t as tall as this one so it doesn’t have the surround piece at the bottom
US $120.05 51% Off | Android 12 Car Player For Mercedes Benz E-class W211 E200 E220 E300 E350 E240 E270 E280 CLS CLASS W219 2 Din DSP IPS
https://a.aliexpress.com/_mPTUacA
Here is the one I am putting in the E when it’s back home. Note the wider screen than the top link but not bottom trim like the 2nd. Also controls are among the bottoms vs the side. Why this version is hard to get I have no idea. I do see the bottom trim version have more memory but it won’t matter if you use CarPlay. Again I put gloss black vinyl around the edges to give it a nicer appearance and blend better with my CF trim.
As for speakers, the previous owner installed different high and middle tone speakers and additionally some frequency splitters and it sounds insane.
