White smoke puf
White smoke puf
Hi Guys,
i had rough idle issues, after looking into O2's voltage reading on the OBD2, i've noticed that reading aren't correct, i suspected my O2's are bad, although no codes were showing,
I replaced all 4 O2's, car ran better, butt still had rough idle
the same day of my replacement, i filled some gas 95 octane, went back home
after maybe 7 hours of sitting, i turned on my car, and it blow a big puff of white smoke !!
within few sec's, it stoped smoking, and nothing came after, tried to rev car to see if there was signs of smoke, nothing
next day, i started the car, a little puff came out !
and the puff will come out anytime car sits for several hours
last thing i noticed p0422 and p0432, and cylinder 7 misfire
oil level is ok though ,,
any suggestions ?
any suggestions ?
Received 4,009 Likes
2017 GLE350 4MATIC
White smoke and rough idle is consistent with coolant in the combustion chamber, for example from a failed head gasket. Tests to diagnose failed head gasket:
- coolant pressure test
- cylinder compression and leakdown
- exhaust gas test in coolant
- sweet smell from tailpipe
- white smoke or steam from tailpipe
- bubbles in coolant
- coolant consumption (level dropping in reservoir)
- "washed" piston crown
- "washed" spark plug
- spark plugs with significant differences in color from one another
Do you have any of the above diagnostic information?
chassis (09-22-2020)
I forgot to mention my engine is recently re built
I noticed one of the breather hoses, the one that fits into the air box is too lean, could it be a reason ?
If was too scared that i didnt take my time to realize the smell.
It was something toxic maybe mixed with sweat ?
Anyhow, i forgot to mention my engine is recently re built, it only have 6k kms on it till now.
Basically your oil will look like a milkshake, and this is bad. Do need drive your vehicle and have this issue addressed immediately.
2017 GLE350 4MATIC
Umm, i didnt check if there was any bubbles, plus i dont have issues with water level / consumption.
@hesham You need to do some diagnostic work. Do the inspections listed and post your findings here. If the engine is recently rebuilt, it is entirely possible the mechanic made a mistake and there is a coolant leak somewhere. It would be unfortunate, but it's in the realm of possibility.
From obd2 readings what possibly could be wrong it
Bank 2 LTFT is high nevative ( - 18 )
And on WOTs it gose to 0.
and from tail pipe on start up its a white puff of smoke only at startup
And i recently notice obd emission test
I have incomplete o2 + cats + secondary.
Update
So i opened my airbox filter, i noticed some oil on breather hose on the top of the cover valve + oil sludge on the back of the cover valve + some on the top of the coil packs + the pcv hose that is connected to the airbox has oil + y pipe
Engine has some blow by from filler cap, looks mostly like oil vapor but it dosent have pressure
Flipped the oil cap it was standing still
And from the backside pcv it had cutted blow by (vapor)
Any suggestions ?
Any suggestions ?
chassis (09-26-2020)
Update
Did a compression test,
Plugs were in good condition, not oily
Cylinder 1 had 60psi
Cylinder 2 had 105 psi
Others were all around 145-140 psi
Cylinder 4 was 175 psi
Could it be a head related issue ?
2017 GLE350 4MATIC
Cylinder 1 not good
Cylinder 2 questionable
Cylinder 4 strange
The M113 should be 10:1 compression ratio, correct? This means 150 psi or so.
Seems like there is high crankcase pressure from poor compression in cylinders 1 and 2. Based on not oily spark plugs and no pressure in valve chest.
What does the white smoke smell like? How does the engine idle?
Have you started reading the warranty document for the engine rebuild work?
Seems to me like a piston ring(s) or piston(s) issue(s). If it was a head gasket issue there is a high probability of coolant leaking out of the engine or into the crankcase. You said you don't see chocolate milk/milkshake. The rings could have been installed incorrectly, they have an up/down orientation and they need to be staggered/clocked. They could have been damaged by overstretching in the installation process. They could be the wrong dimensions/tolerance. A ring could have been forgotten. They could have been damaged during reassembly into the cylinder bore.
Is the shop you used a widely recognized expert in rebuilding Mercedes engines?
Have you done a coolant pressure test? Any bubbles in the coolant reservoir? Any combustion smell in the coolant reservoir?
Cylinder 4 strange
Cylinder 1 not good
Cylinder 4 strange
Cylinder 4 strange
Yeah 1, and 2 have a bad compression
To be honest i though 140 - 145 is low too, a friend of mine said lowest psi they should have is 120.
A mechanic told me it should be 150, and a guy i know that re built his engine said , he's engine was around 180..
Anyhow, yesterday i took the car it stayed maybe 24 hours without starting, i didnt see any smoke on startup
Today morning i started the car, no smoke too
But i noticed that since last time you told me to check coolant level, it had a slight lose of coolant, i topped it maybe with 10 - 25 ml only.
Today, it was lower than last time maybe it need 20 - 30 ml
chassis (09-27-2020)
Cylinder 1 not good
Cylinder 4 strange
Cylinder 4 strange
Forgot to mention, idle is okaay, engine is slightly shaking, plus i dont have misfire codes on obd2
I remember my last engine when it had a bad piston ring, it was shaking and engine noise was weird + smoke out of tail pipe + oily rings
2017 GLE350 4MATIC
Hii, thanks for the reply
@hesham78 Agreed that there are some cylinders with low (bad) compression. You added new information about coolant loss. This is sounding more like a cylinder head to engine block sealing problem. This can be caused by a failed cylinder head gasket or by a warped cylinder head or, less likely, by a warped or damaged engine block deck surface.
Anyhow, will update you guys on whats new.
