Do I need a Bigger Heat Exchanger?
Hello guys I have a 2003 CL55 amg the only mod I have done is a tune and the updated intercooler pump. I want my car to be faster so I was thinking of adding a 80mm pulley or a 77mm pulley the problem is that it is very hard to find information on adding another heat exchanger on CL55's, but I noticed my stock one is huge so maybe for a 80mm pulley I wont have to upgrade or add another one? I made two video showing what it looks like so you guys can get an idea. Please tell me if it would be good enough to add a smaller pulley. With the stock pulley I can do runs back to back and it wont disconnect the supercharger.
Vid #1:
Vid #2:
Vid #1:
Vid #2:
Maybe log your current intake air temps and do a couple pulls back to back and see how warm you getting. If you staying well under control then you probably fine with an 80mm sc pulley with the stock heat x.
Do you know any android apps that connect to obd that can display that?
I have an 83mm and added the PLM XL to my already larger SL HE.
never had any issues with heat even in humid weather in Maryland...might go to a 77mm pulley eventually
I have not done a pull yet measuring the IAT's, I will get the app and log it but I live in Miami so ambient is not that good either, mid 80s rn...
car pulls timing in three stages 94 113 and 149 farenehits. Probably.gonna struggle to keep it under 113 so just try not hit 149 Goodluck..
Oh and to understand your cooling effectiveness you need to run the car hard for a few 'back to back' runs ensure the engine and supercharger are fighting off headstock. Doing one or two runs won't stress the system properly in my experience..
Best way to tell for you and your situation is to monitor iats using torque app or similar. We all got different setups and live in different environments so for some people little cooling upgrade is fine for others they need lots. Not to mention one man's hard driving is another man's cruising... I imagine that the cl having improved cooling with two HE is one step up from a e or a cls with an upgraded aftermarket HE. You could look at getting an uprated pump like the cwa 100 or go the 50 if you wanna save some pennies. that way if you find more cooling needed you can just upgrade the stock HE and you already got the best pump!
similar to me with my 77/header combo with the upgraded heat exchanger and 010. I think you'd benefit from the cwa 50 or 100 especially if you add another heat exchanger I had 010 and upgraded it and saw improvement with the better pump.
Split the cooling you plumb the purge line out of the super charger back to the intercooler circuit instead of res. t it in near your fill line for intercooler and use a pressure radiator style cap and it'll auto purge. Disconnect the t to the main circuit too.
When split drain the fluid via the pump Inlet and then fill with distilled water and water wetter or similar product im running the wetter coz it was first mentioned and easy found here in nz but I saw their supposedly a better product out there dont recall the name though.
If you go to cold climate you may need add anti freeze but in Florida I'm sure you'll be fine with just water and water wetter product..
It is different from e class cars and cls
Yeah I would probably benefit from another pump but I just installed this one not too long ago so a bit lazy to change it out and do the wiring for another pump
Went ahead and order this split cooling kit, its a little more expensive but looks better that the cheap bmw res everyone else uses
http://www.projectb5.com/product/pb5...it-cooling-kit
when you split the cooling do your best to drain and flush the system (intercooler loop). I drained as much as I could by disconnecting the pump and letting it all **** out. I then clamped the return line after the bleed nipple and started the pump while feeding DISTILLED water into the system. I think i let it pump out a few litres before I put the bleed line back into the system and added the water wetter as specified on bottle and let the system bleed for awhile..You can add water wetter to your engine system you can add it to your existing distilled water and anti freeze combo. Id not recommend using just distilled water and water wetter without anti freeze in the engine system as the boiling point would be too low and the system pressure will become too much!
I really want to know which setup would work best for me so I will split the system leaving the 50/50 in both loops and I will add water wetter to both. I will log the temps then do distilled water / 30% anti freeze plus water wetter to see if it helps.
Also I am reading a lot of older threads that say split cooling does not help at all but I guess I will find out soon.
Most of them say the bmw res plus the tiny e class heat exchanger is too little fluid but I think for me it will work better since my heat exchanger is already bigger plus the kit I order hold more fluid then the bmw res.
