Oil drain plug
Oil drain plug
I am about to do the oil change for the very first time by myself :-) Can someone please tell me where it is located? Is it in the center of the mid section? I meant there are 3 belly panels: the front, middle, and rear. It is located in the mid section, right in the center, correct? I just wanted to make sure. Thanks.
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Going to need to remove the front and center panels (front and main sump access, respectively). I forget if that also includes the rear due to the front part of the rear panel possibly overlapping with the rear of the middle panel....if that makes sense.
Also, order some new sealing washers. My main drain plug is leaking. Turns out someone used what looks like a regular washer. And I didn't order any before my oil change, mainly because I've never, ever replaced a drain plug seal/washer in my entire life so I figured why start now?
dustinN (09-29-2020)
The E63 has only one drain plug on the oil pan. But you can also drain the front oil cooler, it also has a drain plug.
