How to put time on cluster?
Old Feb 2, 2021 | 10:43 PM
MartinWake's Avatar
CL55
Putting this in w211 section since w215 section is not very active.
Hello everyone I have a CL55 amg and it used to display the time next to the gear and mode I was in on the cluster but as you know when you disconnect the battery it goes away so you have to go into SVC part then settings then date and time which would always work I would set the date and time and when I click back the time would appear on the cluster.
The problem is now I put the nav cd in to check out how it looks and stuff so the time and date is set by satellite which is good, it set itself to the correct time but I cannot get it to appear on the cluster anymore... Any ideas how I can make it appear on the cluster again?
Video of the gps I thought was cool:
