03 E55 Tranmission Conductor plate/solenoid lef spring Torque
Hi Guys,
I am going to replace the tranmission conductor plate on my vehicle, its an 03 E55, 722.6 5 Speed Transmission.
I was wondering If someone could confirm and add the missing torque specs.
TCU Plug, 7mm bolt - 2.5 nm ??
Solenoid Leaf Springs on conductor plate, that hold the solenoids in - 8 nm
Valve body to transmission - 8 nm
Transmission Pan - 8 nm
also approx how much ATF should it take after ?
Thank you
Thank you
2005 E55, 2009 VW GLI
The torque specs you listed are correct.
I replaced my conductor plate some time ago and I do not recall how many quarts I used to refill the transmission. My guess would be 6 to be on the safe side.
fruitsalt (05-25-2021)
Ended up using about 4.75 liters ( 5qts)
